Question about Whirlpool GGQ8831L Gas Dryer
Samsung dryer smells like gas
Dryer is 2 years old model dv306lgw, warms up initially after 2nd fire starts to smell like gas, and doesn't heat up anymore, I replaced the flame sensor, didn't help. the ignitor is lighting normally.
  • Whirlpool Master
  • 8,220 Answers
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Posted on Dec 16, 2008
Samsung dryer model DV306LGW/XAA smells like gas in the barrel. can anyone help?
Don't do anything more. Call the repair shop immediately. You could potentially blow up your whole house.
Nov 27, 2014 | Dryers
I have a Kenmore dryer that is 4 years old, very basic model, and it heats only part of the time. At times when it is running there is a gas smell, no heat. Other times just the fan blows with no heat or...
The thermocouple may be going bad. The thermocouple is what "tells" the control unit that there is a flame. If it doesn't send it's signal, the control thinks the flame went out and shuts off the gas to prevent an explosion.
Jan 02, 2010 | Kenmore 73952 Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Internal gas leak with Maytag Neptune Dryer.
start the dryer,go outside where it vents if you smell gas outside and only smell it inside when the dryer is running you have a bad gas valve on the dryer and most likely the valve will fail and you won't have any heat.the valve can get noisy too it will chatter when trying to let gas in if you remove the four screws that hold the door on and opposite the door screws but don't remove the door just remove the front panel you can start the dryer to see what's going on in there,i mean you have an igniter and gas coils but i've never seen a coil or igniter do this they either work or they don't so if you smell gas outside where it vents i'd go with the gas valve is bad.usually if you have bad gas coils the coils will work until they heat up and then no flame,when they cool down they will work again but i never smelled gas and the igniter will work or it doesn't not like an oven igniter they can glow but not ignite the flame and you might get a wiff of gas,i think you have a bad valve,you can get a shop vac and vac out around the burner tube and then blow it out with vac and clean out the inside of cabinet so you don't have a fire this should be done at least once a year,unplug it before you clean it out,blow out all around the gas valve sometimes a spider can make a web in there and block the orifice,write back and let me know what you find thanks and good luck.part number is WP306176 on some models you might have to get a pair of tin snips and open up the metal cover that the valve slides into they made the nut bigger for some reason and it doesn't fit through the metal cover unless you cut the cover to make hole bigger lol gotta love it.
Jan 12, 2018 | Maytag Neptune MDG5500AW Gas Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Fridgidaire dyrer three years old
the heater has most likley shorted to yhe frame and needs to be replaced
Dec 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
538 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
