Question about Microwave Ovens
Danby 1000 Watt Microwave is completely dead. Just stopped working right after heating up a dinner.
  • 1 more comment
  • Chris Pickett Nov 27, 2008
    How hard is it to replace the fuse?
    Yes I have a multimeter. There are two screws on the back that have a custom fitting torx or polydrive. I can rig something to get them out. Is there anything charged on the inside to worry about?
  • 456 Answers
One of the most common problems when a microwave is no-lights-plug-it-in-turn-it-on-nothing happens-dead, is normally the high voltage fuse found running from the high voltage capacitor to the transformer(normally), ALWAYS DISCHARGE THE HIGH VOLTAGE CAPACITOR!!!!! IF YOU DONT KNOW HOW, FIND OUT BEFORE ATTEMPTING!!! A CAPACITOR CAN STORE DANGEROUS VOLTAGE!!!! But test your fuse, either by seeing if its blown burnt black or use your continuity function on your multimeter. other than that it will be the high voltage capacitor thats faulty or the small normal fuse could also be blown,sometimes found on a printed circuit board near where your power plug enters the unit.
Posted on Nov 27, 2008
  • 899 Answers
You may have just blown a fuse inside the microwave or the transformer inside has now failed and will need replacing but it will need to be looked at to see what exactly happened
electech
  • 1 more comment
  • jason Nov 27, 2008
    thanks for the rating but that hurts our score as only a fixya helps our score
    I fix these all the time and it will take some time to walk you thru checking and or testing the unit if it needs to be
    but the fuse will be on the power board inside the unit and may look ok but has just got old and quit in the covered areas of it , so testing it will be the only way to be sure it is connecting
    do have a meter?
    yes ! the high voltage capacitor can still hold a charge , so be sure not to touch it even when the power is unplugged as it will still hold a charge( to discharge( only when needed) short the positive to chassi ground)also the negative
    but checking the fuse should be ok , with the power cord unplugged ofcourse
    then pulling the fuse out so you don't measure the transformer
    if that is ok then you would need to make sure that voltage is comming out of the transformer
    let me know what you get from those steps then we will go to the next step if needed
    electech
    as long as the glass fuse is not soldered in then it should be easy to replace the fuse if it is the problem
Microve wILL NOT DO ANY THING COMPLETELY WENT OUT .
  1. Every microwave I've seen has a fuse in the 110 VAC line. Remove the cover or access panels and look for a ceramic or glass tube fuse with metal end caps. Replace with the same value, which is often 20 Amps.
Mar 02, 2015 | Oster OGB61101 1.1 Cubic Foot 1000-Watt...
How do i replace a fuse on sunbeam microwave
If it does not heat, the magnetron tube died. Not worth repairing unless under warranty. Generally the only fuse is a main fuse. If it blew, the entire microwave would be dead.
Feb 04, 2013 | Sunbeam 900-watt Digital Microwave Oven...
My Danby Diplomat 1000 Watt microwave suddely stopped workinmg (display went dark, no door light, nothing). I'm thinking it could be a fuse?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 26, 2010 | Danby DMW1406 1000 Watts Microwave Oven
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Danby Microwave, stopped working, no power, would it be a fuse?
check the gfi it might have tripped that or a fuse if its neither its dead I work in a kitchen and burned up plenty of micros over the last 13 yrs
Dec 02, 2009 | Danby DMW1153 Microwave Oven
Need your insight and troubleshooting on problem w/ our microwave
This could be the breaker at the panel or the fuse inside the microwave.I would check the panel box for any tripped breakers and then the fuse inside the unit.
May 03, 2009 | Sharp R-1502 Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
