Question about HP Computers & Internet
I can not hear anything through my computer speakers. Website sounds, music, or the AOL welcome message. I can only hear if I connect a set of earphones
    Problem Solver:
  • 7 Answers
There should be an audio cord which is green at both ends one end should plug to the corresponding port in bak of your monitor the other should plug into the corresponding green port on your tower. If this doesnt work it may be a compatibility problem.
Posted on Nov 27, 2008
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
The speakers of my lenovo R61i laptop have stoopped working
Welcome to FixYa!
What do you mean it stopped working? No sound at all?
Please try the following:
1. Please make sure the sound is not set to mute. Try to adjust the sound volume.
2. Reinstall the audio driver. You can do this using the drivers disc that came with the computer or you can download the audio driver from the computer manufacturer's website: http://support.lenovo.com.
3. Try to connect an external speakers or headset. If you can hear sound on an external speakers or headset then the internal speakers of your laptop is already defective.
Hope that helps. Thank you for using FixYa!
Feb 14, 2011 | Lenovo ThinkPad R61i Notebook - 7732B4U
I just created my own pc. i decided to go against getting a sound card. My sound works coming from the mobo. I hear the music from my display moniter speakers. When i connect my headphones to the front...
You need to change the sound profile from 2 speaker system to surround sound. You will find this in the control panel area program.
Hope this helps.
Thanks
Jason
Oct 25, 2010 | Logitech X-530 Computer Speakers
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Oct 25, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
My Speakers On My Computer Wont Work But I Can Hear A Buzz Sound?
1st of all click on start->programs-> Accessories->Entertainment->Volume control->options->properties->select Microphone->then click on Mute on microphone. hope this will work
Jun 07, 2009 | Computers & Internet
When i have internation call i cannot hear him but he can hear me.
Check your headset if it is ok. Try to use your headset to listen to a regular music in your computer if you can hear something. Check also your sound setting if speaker are turn on. Or use regular speaker connected to the sound card speaker output.
Or ask him to check his/her mouthpiece if it is ok/ communicating.
May 02, 2009 | Yahoo Messenger
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
