Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
FLASHING RED LIGHT
When we try to turn on our tv, it does not power on and the red light flashes five times. The model is PT53WX53G. Can you help us find out the problem? Thank you.
    Master:
  • 623 Answers
Constant blinking usually infers there is trouble in the jungle ic chip. If that is so in your set the replacement of the jungle chip is quite expensive. More than $150. Probably not a wise investment for a 5 year old set.
The "call for service" is another sign the problem is more than minor.
So, without knowing more I think you are going to be better off by taking a trip to Walmart, Best Buy, Circuit City or Ultimate Electronics and start looking over the new stuff.
You know, I don't have any personal experience with Durabrand tvs, but I was in Walmart today and playing with the controls on one of their sets. After I got it optimized (in the store they always set them up with maximum color and brightness) it was the best looking picture in the store - even better than Sony. The one I was looking at was only a 20 inch for $89, but I was duly impressed with it. Walmart has a Durabrand 27 inch set for $168, which is a good price if the picture is as good as the 20 incher that I was playing with!! Just a thought.
Posted on Nov 27, 2008
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Red power light flashes and set wont come on
Hi
Turn off the tv for five minutes and then turn on..
Can u tell me model no and company name so that i can help u clearly
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
Oct 10, 2010 | Panasonic TH-46PZ800U Plasma TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Won't turn on, flashing red light
It seems you ballast is going out, i recommend you replaced, don't waste money buying lamps with this issue, get the ballast, they run around 60dll so it's a good deal, go to discountdashmerchantdotcom i've been getting parts from them and they offer great service, it's worth giving them a shot :)
Oct 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
