Question about Dell Dimension 3000 PC Desktop
Print spooler is not running
When my niece and nephew was on my computer they stopped the printer and jammed it and did not tell me what they did and deleted my printer off my files. I could not find my disc so I could not install back and now I can not get the the computer to see another printer when I install it to get the printer to print. The printer shows up in the files but not in the hardware and printer section. I have tried the add printer section. I have tried help and support sections.
Go to the website of the printer manufactuer and download the drivers for your printer. upon installation of the new drivers the spooler will restart, to manually start the print spooler service ...........Click start.......then click on the control panel.........then click on administrative tools.........then services..........scroll down the list until you find the spooler and right click it and set to automatic.........Reboot
Posted on Nov 27, 2008
My lexmark p707 has just stopped printing. It keeps cancelling jobs and tells me to reinsert the cartridges (which I have done). But is still not working. Help pls?
It could be due to the Print Spooler on your computer. Please follow steps below to ensure print spooler service is running and print queue is clear from pending print jobs.
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Jun 23, 2011 | Lexmark P707 Photo Jetprinter InkJet
Message on PC screen tells me "printer is busy"
Make sure there are no print jobs stuck in the queue. If you're using Windows, go to the Control Panel > Printers > double-click on the Lexmark print object. Delete all print jobs pending. If you can't clear all print jobs, follow the steps below:
Reboot your computer. Then, try to scan again.
May 25, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Printer will not print the ink packages are new but the indicator on print que shows (?) on both black and color indicators. the que shows printer 1 to 3 % progress then stops. thank you for your help
It could be that the print spooler service on your computer has stopped. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 23, 2011 | Lexmark X4650 InkJet Printer
MY PRINTER WONT PRINT, BUT WILL SCAN AND COPY
What is the operating system of your computer? Make sure the printer software is installed on your computer (available at http://bit.ly/g1FS2M) If you're using Windows, please check the Print Spooler service on your computer and make sure it is enabled. To make sure the service is running, follow the steps below:
2. type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 17, 2011 | Lexmark X4530 InkJet Printer
My printer is telling me there is a job in the que thats preventing it from printing ...When I run the troubleshooter it tells me its fixed ! But i still see the error msg and the printer will not print
You need to delete all jobs in the print queue, see instructions below:
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and type the following, pressing enter after each line:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Jan 08, 2011 | HP Color LaserJet 2600n Printer
HP 5440 printer will not print or test print; no paper jam; disconnected USB cable at both printer and computer; cannot empty print quieu(error oxooooooo5); cartridge track not stuck
I had the same problem.I bought another printer.
Temporarily here is what I did. I used a USB cable that has lights. Whenever the print spooler jammed, the light would not be on. Then go to START, RUN, type in "CMD". This open a DOS window. Type "NET STOP SPOOLER". Wait for it to say it has stopped. Then type "NET START SPOOLER". It will start, then you can close the DOS window.
Unfortunately this helped only half the time. Some times I would reboot, only to have my job print on restart!!!!!
good luck
Feb 22, 2010 | HP Deskjet 5440 InkJet Photo Printer
My printer wont print it has a spooler problem.
To start and stop the print spooler
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
    Click Stop to stop the service.
    Click Start to start the service.
Notes
  • To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
  • When you stop the Print Spooler service, it might stop other dependent services.
  • The print spooler runs under the Local Computer system account by default.
Once you get here you should be able to restart the print spooling service.
Mar 25, 2009 | Epson Printer
Printer queue jammed
Simply rebooting your computer should fix that. If you have Win2k or XP, you can also open a command prompt and type 'net stop spooler', and when it's done type 'net start spooler'. That stops and restarts the spooler service (which controls the print queue) and may take care of it. But a reboot is easer and more likely to be successful.
Jul 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Dell Dimension 3000 PC Desktop Logo
67 people viewed this question
Alun Cox
