OLDER SONY TRINITROn fuzzy pic and audio..
Hello I have an older SONY TRINITRON COLOR TV..it worked fine.Now the picture come in black & white and fuzzy..sometimes color will come in after 30 minutes,
So I ahve fuzzy , buzzy audio and picture.
I heard the tuners were bad in these, as well as IF (don't know what this is).
the model is SONY KV2092R year: FEB. 1998
CAN u help?
  • 556 Answers
SOURCE: color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Posted on Oct 02, 2007
  • 14 Answers
SOURCE: Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Posted on May 16, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
Maciso
  • 125 Answers
SOURCE: Sony TV Repair
crt going bad it is a common problem on sony old sets
Posted on Aug 06, 2008
SOURCE: fuzzy pic. where to get a new tuner??
Resolder all the joints who looks cracked.Good luck
Posted on Sep 19, 2008
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV's is making a fuzzy noise from the TV's speakers but when played via my amp everything is fine....
Hello
The audio output IC of your TV is faulty. It should be replaced with same type and number. If there is some loose sodering on the solder terminals of this IC, this type of fault can occur too. So check this first, before replacing the IC. Ok
Nov 22, 2011 | Televison & Video
I have sony wega trinitron and a day back purchased a new LG DVD player but the picture is black and white.I tried the Setup to change the color from auto to PAL but the option color change is permanantly...
Hello
Your TV model has only NTSC system with it. No PAL or SECAM. It is not a mutisystem compactable one. Check whether your DVD has NTSC playback option. If it has, you can see discs writed in NTSC system through your TV. If it has not equipped with that system, it is useless for your TV. Sony KV32FS120 and KV36FS120 models are only meant of US standard, and have only NTSC system with it. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2001 sony wega 36" tv tube
If you turn the color all the way off the picture should have good black and white if not the crt is at fault. If it is good it could be the jungle ic or the possibly the red color driver in the crt board
Apr 06, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV colour problem
how did you explain trouble do you have a problem on tv with color
board ,surely a capacitor has few' capacity' for making the driving on
color that can  be rarely
delfo
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
