Question about Casio Parts Cash Register PC Desktop
Te-2200 does'nt work
Only display "p1 0"in PGM mode and display " 0 " in REG mode
  • mrchan98 Nov 27, 2008
    i see these message:
    Ver.: 4207
    label: aa0aaa
    ver.: 4434
    label: aa0kah
    fc: eb080000080002
    no, i don't have any backup.i just bought few hours
  • 737 Answers
Hi.
You may have lost all of the programming.
I need to see the MAC code.
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down.
Turn power on at wall.
When you see 'FFFFFFFFFF' on display, let go of RECEIPT FEED.
Press SUBTOTAL
Now look at the print out and tell me what the big number is right at the bottom.
Mark
Posted on Nov 27, 2008
  • flexion1
    flexion1 Nov 27, 2008
    Doesn't look good.
    If it was programmed by a dealer, then there is probably a backup of the programming. Otherwise, do you have any backups yourself? There may sometimes be quite a bit of system programming lost.
    This problem is rare unless it has sat for sometime or has a faulty battery.
    Mark
  • flexion1
    Ok. Then the best thing to do would be to get a Casio dealer to drop a standard program into it for you and then you can do the final user programming yourself or they can do the whole job if you prefer.
    Mark
Error FFFFFFFFFFFFFFF
Hi. This is normal when you haven't changed the batteries on time. It no longer has the power to backup the memory when you get a power cut. You can change the batteries now and try to recover the memory if it is still there. MAKE SURE you leave the POWER ON when changing the batteries as there may be enough in them to hold memory but not if you turn power off. Once you have new batteries in it and the FFFFFFFFFF is on display, turn key to Program or PGM mode and press subtotal. It should print out. Turn key back to REG mode and try it
Jun 09, 2016 | Retail Supplies
Getting error in E004 for Casio TE-2200 reg how do I get out and running
Try this:
Turn key to PGM (program) mode
Turn power off at the wall socket
Hold down RECEIPT FEED button (keep your finger on it)
Turn power back on and wait 5 seconds before taking your finger off of the receipt feed button (the paper may feed out. This is normal).
The LLLLLLLLLL part of the display should change to FFFFFFFFFF.
Press SUBTOTAL once and wait for the printer to issue a receipt.
Turn key back to REG mode and try it. You may need to sign on using a clerk button or a clerk code if you use one.
Sep 22, 2015 | Retail Supplies
Getting error e004 on te-2200
Try this:
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
E004 Error INIT/FC
You need to finish the flag clear.
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn back to REG mode (you may need to sign back on)
Feb 28, 2011 | Casio Parts Cash Register PC Desktop
Tk 2300 has error mode. How do I get it out of
hold down the receipt feed button and turn the key to PGM. then wait a few seconds and release the button. next the display should have all "F's", next press subtotal. Wait for the machine to finish and turn the key back to REG and sign on
Nov 04, 2009 | Casio Parts Cash Register PC Desktop
Casio tk-6000 error 26
switch off the register and do the following;
1. Turn the mode switch to PGM
2. Press and hold RECEIPT FEED
3. Power on and release the RECEIPT FEED key
4. 'FFFFFF.. ' will appear on the display if not, repeat 3 above.
5. Press SUBTOTAL key and wait for 5 seconds, the display will show 0.00
6. Turn the mode key to REG and you are done.
Sep 30, 2009 | Casio TK 6000L Cash Register
Sharp ER-A330 cash register. Have to enter Cashier # every sale.
You might need a special key to program this change, but try this:
  1. Turn the key to PGM
  2. Enter 9910 . @/FOR CA/AT
If you don't get an error, you're done. Turn back to REG sign on one more time, and try two or more sales in a row.
If you get an error, this kind of programming is disabled in PGM mode. you may have to take it to a Sharp dealer who has a Service key. Your MA (Manager) key can get you to any position marked on the Mode Switch, but the SRV key goes to two more unmarked positions beyond PGM. If you have that key or find a dealer who has, turn it one notch past PGM (to 7 o'clock position).
Enter 910 . @/FOR CA/AT
[Yes, it's a different number than in PGM mode.]
If you ever want to make cashier entry compulsory again, do the same thing, except enter 100 just before touching the CA/AT button.
The reason Sharp doesn't pass SRV keys with its registers is that you can totally mess up your register if you make mistakes with this key. Don't experiment with it, or your only hope may be to wipe all machine memory to get it working again.
Sep 29, 2009 | Monroe 2020Plus Calculator
Can't enter casio qt-2000 pgm mode
You can only enter PGM mode as manager.(our manager key is #1). The, you are brought to a admin menu.
Jan 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Raidoshack 1000 channel scanner
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Mar 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Casio Parts Cash Register PC Desktop Logo
336 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
