Back to:
Tags:
Toshiba e310 Pocket PC
Toshiba e310 no reset
posted by mustanger on Jan 24, 2007
When it is reset the screen is just a series of vertical lines or just plain white. if it beeps it isone quick beep.
It appears to do things when you move the stylist over the screen yet can't go to the main screen.
I have followed factory reset (switch off then on), (reset power till screen on then release power), (disconnect power plug from battery to board). NOTHING worked. Also have a 740 and has same problem. Open for suggestions. Factory is not supporting ppcs yet less than 4 years old. HELP!!!
Doug
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 29, 2008
Helpful (85)
prakashdavid
Rank:Apprentice Apprentice
Rating: 87%, 8 votes
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba e310 no reset:
I don't want to Accept this solution
Can you Help with these PDAs problems?
I purchased a toshiba e310 off ebay for my daughter. I...
I wonder if I can upgrade Toshiba e310 with Microsoft...
Hello tech expert, Could you please assist me on my...
Can the OS be upgraded to the latest version
I was given the e310 last night from a friend who had it...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
