Question about Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop
No Power Hi, I tried to install a Kenmore 42701 to my existing cable harness from a previous cooktop (120V AC), but the unit won't turn on. Please advise. Thanks.
  • Danny Nguyen Jan 30, 2007
    Hi Catriver, thanks for your response. The model number is 911.42701100. I measured the voltage at the terminals and the reading was 120VAC. But the cooktop didn't get any power.
    Thanks.
  • Danny Nguyen Jan 31, 2007
    You're right Catriver. I measured the wires and got 120V from each outer terminals to center but nothing across the 2 outer terminals. That must be the problem then. Do you think my stripper is broken? Thanks.
    President:
  • 878 Answers
Brown, I need the first 3 letters of that model number. This model number is not complete, it comes up as a television...Catriver..post back.
Posted on Jan 29, 2007
  • Ron Marek
    Ron Marek Jan 30, 2007
    Brown, you need 220V going to this cooktop. Check the installation manual. The voltage requirements should be in there. On the terminal block where the power connects you should have 120V from each end to center and 240V across the two outer terminals...Catriver..post back.
I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
Unit on light stays on when unit is off
You need to check the switches. If no problems with the switches it is in the circuit for the indicator light. This is easy to check and the parts are inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru performing these checks.
Apr 10, 2010 | Kenmore 30 in. 42701 / 42702 / 42709...
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Connecting to ground or neutral
SOMETHING DOENST SOUND RIGHT ABOUT THAT AT ALL. i would contact an electrician, would not even want to venture a guess as to whats goin on . let alone advise to hook up a ground to a nuteral and cap the nuetral.theres somehtin up there . i would call in a pro on that one
Mar 08, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Logo
107 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
