Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Electric start gas range
When I try to light the rear left and front left burners, they spark but don't light. When I try to light any of the four burners, the back left sparks.
What's going on ?!!! The top burners light but the gas stove does not light.
    Sergeant:
    Champion:
  • 311 Answers
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Posted on Nov 28, 2008
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
1) Right rear burner electric spark always arcs no matter which of the four gas knobs I turn. 2) Right front burner electric spark only works (arcs) when left two burners panel is unplugged or removed.
Sure. Once we realized that you'd charge a fee, we went to our local brick and mortar appliance repair store and got the info needed for free. What happened to free advice?
M
Dec 02, 2008 | Amana Kitchen Ranges
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
You either have a short in your electronic ignition or the ignition board is defective. Check the wiring to the ignition board for shorts. also check and make sure you ignitors are well grounded.
Dec 08, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
