Question about Electrolux Washing Machines
I have just bought a brand new washer it's a 8kg water rid one and every time I wash especially a dark load the clothes come out with suds residue marks all over the clothes. I use front load soap powder only and have tried different amounts with the same results every time which is very annoying it means i have to rewash every time. I would of thought a brand new washing machine would'nt do this as my previous machine was a front loader and had no problems at all with it . please can you help?
  • gaylepaul Nov 27, 2008
    the reply does not help me at all and yes the water temp is fine and yes the powder draw is empty i have been washing for a lot of years and never had this problem before iI should have stayed with my front loader.
    Scholar:
  • 174 Answers
Use liquid detergent only.
Posted on Nov 27, 2008
  • Electrolux Master
  • 19,396 Answers
Check that water is heating properly, and that the detergent into the drawer is being flushed.
  • 4,806 Answers
Lol i have had the same problem with my machine
  • 2 more comments
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    i have found it to be a combination of overfilling the drum (even though i thought i hadn't) and the rinse cycle, my machine takes a load of 5kg (that means wet weight) so what i did to resolve the problem was to give it a couple of extra was cycles, and sometimes i use liquid!!
    My washing machines fine
  • Lee Hodgson
    give it a couple of rinse cycles sorry
    regards
  • Lee Hodgson
    strangely enough top loaders are supposed to be better that front loaders!!!!!
    I don't know why but in some washers this tends to happen, this is why i do a couple of extra rinse cycles
    regards
  • Lee Hodgson
    if all else fails then change from powder to a liquid detergent..
    hope this works
    regards
  • 4,806 Answers
Surprisingly i have the same problem
MAH2400AWW washer has a code flashing SUDS and I cannot open the door. I have rewashed the same load 5 times to get rid of soap to no avail
In most cases it the type of detergent. The new machines require a detergent marked as "he" or "He" for high efficiency. They are formulated for low suds because the new machines use less water to clean the clothes. You also may be required to use less detergent for that brand of washer.
Another question: Do you have a water softener system installed or is the water in your area naturally soft? The ph of the water effects the sudsing.
Oct 20, 2016 | Washing Machines
I have a whirlpool duet washer (2008). The SUD light came on and i have never seen this before. what is wrong?
Are you using a good brand of HE detergent? Is the water draining. If draining. Start the washer. Empty and no detergent. After a few minutes, are suds in the washer? If so cancel and drain. Do again. If so cancel and drain. Add 1/4 cup of cooking oil. Start unit. Let oil rid unit of built up soap. Detergent (overuse) can build up in unit and on clothes. If this does not help you. Give more information,( noises, wet clothes) and I will try to solve your problem.
Mar 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Water and suds leaking
if you have any suds your either using too much soap or the wrong kind. does the washer drain all the water out each time? is this a new machine where you're washing your clothes in it for the first time? I've seen clothes with resisual soap in them causing over sudsing.
May 20, 2010 | LG WM2487H Front Load Washer
Gives the LE code
Here is text of very helpful email from LG
When you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that
may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the
amount you would normally use in a conventional top-loading machine. However,
the HE and the conventional detergents are different formulae, and your machine
will not perform as efficiently or effectively. Using half the required amount
of regular detergent will
give half the cleaning performance. As the new LG washers accept a larger than
usual load, the cleaning performance could be further reduced. In addition to
the reduced cleaning, there will be oversudsing. The excess suds will cause the
washer to stop and rid itself of the suds before continuing its cycle. Getting
rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which
can result in mold and even mildew growth in your washer. Should this occur, do
a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any
odors accompanying it. This procedure may need to be repeated a couple of times
depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water
temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures
the detergent/suds residue in the water during the rinse and then makes an
adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance
is detected or if the suds removing program operates, the wash time will be
increased.
A built-in water heater in the washer assures that incoming water is the correct
temperature to optimize cleaning performance. Most laundry detergents must be
activated at certain temperatures to work correctly. We use thermisters
(electronic thermostats that have a high degree of accuracy) to detect incoming
water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is
pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This
increases the mechanical action to achieve best cleaning performance. The
rollers gently move fabrics
along in the wash cycle.
This action aids in reducing the amount of water required for thorough
cleansing. In contrast with a top-loading machine, which always fills the
machine to a precise measured level of water, depending on the size of load you
select (small, medium, large), the LG machine will "sense" the size of the load
and only recirculate a minimal amount of water, thus making it very energy
efficient, efficient in the use of detergents, and extremely efficient in its
water usage.
Forced Water Circulation in the washer pumps water during the wash. It
recirculates it back up and over the laundry to further increase mechanical
action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional
machine, that it is recommended to dry the seal when you are done with your
laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the
same wash cycle. Different fabrics need to be washed in different ways. Always
sort dark colors from pale colors and whites. Wash separately as dye and lint
transfer can occur causing discoloration of white clothing. If possible, do not
wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items
should not be more than half the total wash load. Do not wash single items. This
may cause an out-of-balance load. Add one or two similar items.
Hope This help
Good Luck!!!
May 03, 2009 | Washing Machines
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
LG TROMM WASHING MACHINE FRONT LOAD
increased.
water usage.
Hope This help
Good Luck!!!
neo
Sep 18, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
253 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Chris Hall
Chris Hall
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
