Question about Linksys Wireless-G Broadband Router
Can't get linksys install cd to work on my laptop, new out of box, other cd's work just fine any suggestions
  • 118 Answers
One solution is to use a cabled connection to the router so you can download the drivers from Linksys. You really don't need it, since WPA2 is supported in the latest version of XP and Vista. Just set the router up via its webpage and select WPA2, put a good long password in there, and use the same password for you laptop.
Posted on Nov 27, 2008
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
The password comes back as invalid when I just used the same password to connect my Windows based laptop and my iphone to the Wifi......
Report Trouble with Linksys router WRT54GS [Solved/Closed] johnkwit 2Posts June 16, 2008Registration date - Jun 17, 2008 11:17pm BST - Last answer on Jul 27, 2010 5:27am BST hello Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
Any help would be apreciated
Jan 05, 2011 | Computers & Internet
Wireless router is working fine to connect to the
Did you install anything new on the computer you are working on? I suggest you to check the version of your printer driver software according to the driver CD you had and reinstall the compatible version of the driver on your computer with a USB cable connected after totally remove the drivers and settings for that printer on your computer now.
Jul 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I was trying to connect a new laptop to our home wireless network via wrt54g. on installing our old linksys disc into the new laptop it kept sayin not connected to the internet even though it was hardwired...
Your mistake was to run the CD on the laptop. When a router is working and computers are using it NO CDS ARE EVER NEEDED. Your laptop will connect to it just using what is already in the computer.
When you go to starbucks and use the internet they don't give you a CD to install do they - they just give you a password - that is all you need. The fact that you are hard-wired means you don't even need a password.
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Linksys install cd will not load any suggestions
Since the setup CD is not working, you can manually configure the router by accessing its setup page , and if you're not familiar with that it will be better if you can contact Linksys tech support so a tech can wlak you through with the process this is there number 800-3267114 they are open 24/7....
Nov 27, 2008 | Linksys Wireless-G Broadband Router
Still didn't work
did you install the driver? you also have to be sure that you installed a vista driver....if your cd-driver for linksys does not work download the vista driver from teh linksys website. i also suggest if you can't install the vista driver for your linksys properly i suggest you copy the driver to a cd and install it from there( meaning install the router using the cd). I also suggest you uninstall it from the control panel- add/remove programs before installing the new driver. also try installing the driver or linksys w/ your firewall off it also has to be configured to allow the program
Jun 09, 2008 | Microsoft Windows Vista Home Premium with...
Can not connect adapter to laptop no installation CD-Rom
you have to install the driver for it to work and i assume that is not the case as you have no cd. Go here to download the driver. http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0993490190B03 When installed go to the properties of your adapter in network connections, then click on tcp/ip line and then properties and ensure obtain ip address automatically is ticked and press ok. You may also have to use the home network connection wizard if you havent previously to share documents over your network.
Apr 13, 2007 | Linksys Wireless-G WUSB54G 802.11g/b
Linksys Wireless-G Broadband Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
