Question about Whirlpool Refrigerators
Ice box remove?
I have a old fridge that have a lilltle ice box in the left top corner in the fridge. all it has ever done is ice up in and outside the box. is there any way to remove it?
    Sergeant:
    Champion:
  • 251 Answers
No that was put in there by the manufacture u could but u would damage the refreg
Posted on Nov 27, 2008
The box on the top (outside) of the fridge is leaking water.
perhaps that is where ice maker get it's water .stand on a chair and look it over .
Jan 28, 2015 | Refrigerators
Sub-Zero 590
Ignore the fan operation... That is perfect.
You are likely experiencing a DEFROST failure
(most commonly a defrost timer failure)...
part number 3081180 item 69 on your exploded
top view (top right side as viewed from the front).
There are typically only three (3) elements to a DEFROST
circuit:
- Defrost Timer (as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per YOUR DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
guaranteedparts.com http://www.guaranteedparts.com/picture_library/Subzero/Subzero-500%20Series/590.pdf
Sears
http://www.searspartsdirect.com/refrigerator-repair/symptom/REF0003.html
Carnac the Magnificent
Apr 06, 2017 | Sub-Zero 690 Side by Side Refrigerator
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Loud sound coming from back of fridge. Pulled out from wall. sound like it's coming from the lower left corner when looking at it from the back. Looks like i'd need to take the lower panel off to inspect...
Hi Rick,
Sounds like the now infamous 'fan icing up' caused by a design fault of the fridge evaporator cover assembly & evaporator heater.Contact Samsung.You may find that these components are covered by by an extended 5yr. guarantee. Good luck.I was 30 days outside.
Cheers,
Ron Swift
Nov 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Hello I have a 1960 general motors fridge. I was breaking ice off the ice box and punctured the outside box and all the gas escaped. Can you help me?
dear best solution is change the old ice box.if you can not this then repair the box and then fill the gas from repairing shop.thanks
Aug 22, 2009 | Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Apr 10, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
