Question about Jwin JD-TV1300 13 in. TV/DVD Combo
HELLP ME i try to play a vhs in my vcr and it will only play a few seconds before it just stops and i have no idea why and i need help soon because it is a tape that i am borrowing and i need to return it- but i need to be able to watch it first
    Genius:
  • 1,139 Answers
This sounds like it could be a tape sensor problem. Granted this is the worse case, but this is what this sounds like. In VCRs as the tape is pulled around the drum, a sensor determines if the tape is in the proper position. However if the tape is not the sensor triggers an unload sequence which unloads the tape and sometimes auto ejects the tape. I would forst try to use another tape just to see that it is not a tape problem (which 9 times out of 10 it will not be). After trying the new tape, see if you can get this looked at, by a qualified technician. I have done these repairs before and if it is an optical sensor what usually happens is magnetic dust gets on the sensor lens and causes problems, if the sensor is the switch type the switch tends to get out of alignment and needs to be set correctly or replaced. I hope this helps
Posted on Sep 03, 2007
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
How can I get VHS tapes to play?
try to run a vhs cleaner thru it and it should help alot
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
My vcr won't play.
Sounds like a bad belt or the tape isnt loading into case correcly bad rubber idler assy.
Oct 23, 2008 | Quasar VHQ400 VHS VCR
Problems playing vhs tapes
Have you tried the VCR on a different TV? Could be a faulty VCR and not the TV.
With what kind of cable do you have the VCR hooked up to the tv with? Composite or Coaxial?
Jan 11, 2008 | Televison & Video
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
Jwin JD-TV1300 13 in. TV/DVD Combo Logo
37 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
