Question about Nintendo Wii Console
We moved our Wii to another location and a new TV and now the remotes point and click is inaccurate and we cannot easily aim at all. I thought it was the bar sensitivity but I think that's fine. Any ideas?
  • 395 Answers
Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them. (How to)
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu (click here for directions on accessing this feature).
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar. Please click here for repair information.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further
Posted on Nov 27, 2008
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
I cannot get my Wii remote to move the cursor so I can click on to the net flix channel. What button do I push?
The WiiMote cursor is moved by you pointing the WiiMote at the screen. The cursor will move based on the signals it receives from the sensor bar, which shoudl be placed at the top or bottom of your TV.
May 15, 2011 | Nintendo Wii Sports for Nintendo Wii
We recently had a power outage. After this, the Wii console power light would not come on. I unplugged the power supply adaptor on both sides, left it 2 minutes, and plugged back in. Now, the Wii console...
The best solution would be to just move the sensor bar to the top of your TV. Then you could change the settings back to the bottom and move your sensor bar back. If that is not an option, just try your best to get back to the settings to change it back.
May 01, 2011 | Video Game Consoles & Games
Wii remote only works pointing away from the tv and upside down? ANy thoughts or experience woul dbe appreciated
if you have your wii in that direction(away/upside down) from the tv then that could be the problem try setting up the wii next to your t.v. Hope this helps
Jan 15, 2011 | Nintendo Video Game Consoles & Games
No response to remotes
if the batteries are down change them if it still doesnt work then walk to your console at the left of where to put the disc open the cover and open the cover in where you put the remote batteries and then press sync in the wii remote and wii console just click them dont keep pushing the for more that 10 seconds or everything that is on will turn of except the wii it may not work if it doesnt ask the question for me helper9 that it still doesnt work
Feb 13, 2010 | Nintendo Wii Console
Wii problem - Can't get past Select Language screen
keep getting a error has occurred,press eject button and remove the disc,then turn wii console off and refer to manual cant get past this.
Dec 25, 2009 | Nintendo Wii Console
Wii remote moves the wrong way on screen.
If it only does it during Call of Duty then go into the options menu in the call of duty game and go to the controller settings. and there should be a "invert aim" or something along those lines in there that you can turn on and off....you want to have it off in order to have it go right to right and left to left. That sounds like your problem it probably got accidentally flipped on.
Sep 03, 2009 | Nintendo Wii Console
My Wii remote blinks blue lights but it won't work with the Wii
you have to press A and then the remote buttons at the bottom will turn blue and make sure you have the gray thing that sits on top of ur tv is where you can directly aim the remote at and the little hands should appear.:) Hope it helps.:)
Jun 20, 2009 | Nintendo Wii Remote Controller
Wii
check the sensor bar is plugged in and aimed correctly.
Jan 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
270 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
