SOURCE: 95 Dodge Dakota 4 Cyl Dies
try replacing the coil, my 2.5 did the same thing, and after changing plugs,wires,distributor,rotor,rotor button . the last thing i repalced was the coil and i have not had an issue since. all work was done about 6 months ago.
SOURCE: 1995 dodge dakota will not time properly
Still sounds like it jumped time. I was taught to time without a light. Advance the timing while running until it sounds its best and then back down maybe a quarter turn. Drive to see how the power is. If its better, its a temp. fix to belt replacement. Just to be safe check the compression on the cylinders first. Make sure you didn't bend a valve. Good luck.
SOURCE: dodge ram 1500 5.9L jurky when you drive
Check the exaust backpressure before the cat converter. Should be less than 1lb. Write back.
SOURCE: 1998 dodge ram pickup 318 eng.
If the engine seems to run fine over 1450 RPM maybe there is a vacuum hose leaking or EGR valve is slightly stuck open. Any help from the OBD II trouble codes? Or is there simply no MIL and no stored information in the OBD II computer read at the local parts store through the connector by the drivers knee?
SOURCE: hello timing is off and jumping all over the place
mcdevito75 here, Could be a worn timeing belt, a crankshaft position sensor. Have your local shop check it out.
I removed the exhaust before the cat and it still does it.
