Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon MP 210 gives E5 error and will not print. ??????
  • 13 more comments
  • Anonymous Dec 03, 2008
    i have the same problem
    After refill ink cartridge on my MP210 E5 turns up.
  • Anonymous Dec 04, 2008
    Canon MP 210 gives E5 problem
  • Anonymous Dec 06, 2008
    Happens to me too
  • cobra07 Dec 07, 2008
    mi dice errore 5200 ho appena messo cartuccia a colori nuova
  • Anonymous Dec 07, 2008
    I have the same problem vwith code error E5. Please help!
    forboyleryahoo.com
  • rafiqilahi Dec 13, 2008
    same problem
  • niapc Dec 15, 2008
    same issue pleas help
  • zoran04 Dec 25, 2008
    mee too
  • Anonymous Feb 03, 2009
    me too :(
  • youcansendme Feb 05, 2009
    same problem
  • Anonymous Feb 09, 2009
    the printer make strang sound and does not work
  • imibam Feb 09, 2009
    my printer make strange sound and does not work
  • andreiit Apr 07, 2009
    e 5 error and doesn' t print and doesn't reset like it showuld
  • Anonymous May 12, 2009
    Mein Drucker zeigt E5 an und macht gar nichts.
    Er druckt nicht, kopiert und so weiter.
  • 3,230 Answers
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
good luck
Posted on Jun 21, 2009
2 Suggested Answers
debroy
  • 174 Answers
SOURCE: Canon MP 210 gives E5 error and will not print.
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Posted on Nov 27, 2008
Cannot align printer head on Canon mp 210
You need Canon mp 210 set-up disk to align print head. Insert the disk in your computer and follow the instruction.
Jul 06, 2011 | Canon Office Equipment & Supplies
I have a PIXMA MP 110 CANON and when i go to print it says CARTRIDGE IS JAMMED PRESS OK. The computer says it is a ERROR 5100 problem and press OK AND IT SHOULD WORK .but it doesn,t. The cartridges are...
You are facing e5 error which cannot be solved.
For Canon printer, if you refill about 4~5 times, especially color, the printer does not read that particular cartridge.
Well for solution? You need to replace the cartridge with new one.
Just blame Canon....
If you would like to save money, try refill kit by "ROADINK".
At least you can easily save $100 for color cartridge (facing e5 error after 4~5 times of refill)
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    E5 flashing - do not want to use colour ink
    use any color cartridge that is no sort & see canon error e5 solution
    Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
    What is e5 error
    E5 error code occurs in certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
    Feb 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Error code 6000 on canon pixma mp210 stops me from printing
    Error 6000 means - The specified file could not be encrypted.
    Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
    Good Luck!!!
    Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    walljack.
    Nov 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Error e5 in mp 145
    change a new black cartridge. the problem wont come back again.
    Oct 06, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Canon PIXMA MP210 Photo All-In-One Printer Logo
    2,832 people viewed this question
    old marine
    old marine
