Question about Montgomery Ward (223600UP) Heater
Wick and manual for Montgomery Wards Windsor kerosene heater
I have an old Montgomery Wards Windsor keresone heater. Where can I get a manual and a wick
I believe I have the same stove in like new condition i purchased at an auction a year ago. I need to locate a manual for it but so far cannot. Mine has a large round tank that sits on the back of stove, two burners inside with tank coverings, the model #685800R and the #974 is on a metal plate on the back of the stove. It is brown with vent slits on both sides and has a square door on the front. Do you have an owners manual with yours?
Posted on Nov 20, 2012
Hi, I have a Montgomery Ward Sunheat heater. It's a dual burner enclosed type with a door on the front. The fuel tank is cylindrical and about 1 1/2 - 2 gallons. The cap has a needle valve and when turned upside down releases fuel to the burners by gravity. The whole heater itself is rectangular with louvers on the sides and top. I don't know what wicks go in this or if there are compatible replacements out there.
No 84ALO5800A is the only I.D. or Model No.
Thanks,
Jack
Posted on Dec 14, 2010
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 03, 2013 | Water Heaters
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
WILL NOT START BURNING. REPLACED BATTERIES, GOOD SPARK. CLEANED. NO FIRE
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Dec 10, 2010 | Northern Tool 10,600 BTU Radiant Kerosene...
Is it true that if you use moth balls with the fuel in my kerosene heater it burns cleaner & there wont be any build up on the wick? I get alot of soot build up on the wick of my kerosene heater &...
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Feb 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Set to automatic extinguisher
Mine is missing too! Pull the front grid up, take the element out, and you will see a plate covering the wick area. Slide this plate to the left until it clicks into place. Now you're set! If your wick is old, you might need to 'prime' it by wetting it with some kerosene.
Dec 22, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Montgomery Ward (223600UP) Heater Logo
597 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
gbob59
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
