Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
My kitchenaid dishwasher model kudpo2frsso built in lights are flashing normal and cancel I shut off the breaker for 20 minutes pressed Normal heat dry X2 Then cancel x2 but to no avail. Any suggestions its the day before Thanksgiving HelpI T The Normal and Cancel lights are flashing simutanuously and the dishwasher is not working at all
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Posted on Nov 26, 2008
ndguy2481
  • 251 Answers
yes u need to call an electrican u have to much load on that side of the house
Posted on Nov 27, 2008
s_4u_11
  • 535 Answers
chk the switch of ckt bord or chak the pannel of ur dishwasher
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Clean light keeps flashing and will not start.
Try the follow key dance, all within 5 seconds push:
HEATED DRY --- NORMAL ---- HEATED DRY --- NORMAL
wait for about 2 minutes then hit cancel
May 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Green light flashing and water does not seem to be circulating in Dishwasher
Press the following normal, heated dry, normal, heated dry, wait till the lights all come on and then off again, press cancel and wait 2 minutes. This should reset the control, if you get the same symptoms returning we need to dig deeper
Apr 23, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
121 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
