Foreign object in DVD player - Televison & Video
  • 5 more comments
  • Monty Aranui
    Monty Aranui Nov 27, 2008
    Problem with exrtracting paper from DVD drive in Acer Aspire M1610 Last expert stated take the screws off. What screw Where?
  • Monty Aranui
    Still stuck with the problem Where are the screws situated to take the top cover off. I presume the last expert realises the Model Acer Aspire M1610. Cant see any screws to extract
  • Monty Aranui
    Please indicate how the top cover can be removed Model Acer Aspire M1610
  • Monty Aranui
    How do you unscrew the lid when there are no screws visible Acer Aspire M1610
  • Monty Aranui
    How do you take the DVD drive out Acer Aspire M1610
  • Monty Aranui
    How do you Extract the DVD
  • Monty Aranui
    Model is Desktop Acer Aspire M1610
  • 905 Answers
Take a small paper clip and put it in to the little pin hole in the front , this will open the door so you can get the disc out
then to get the drive out of the computer it will have to be opened up and there are screws in there that hold the disc drive in ( thats if you want to replace it )( the disc drive )
electech
Posted on Nov 27, 2008
    Scholar:
  • 174 Answers
Get a dvd cleaner kit form your nearest store.
    President:
  • 624 Answers
You will need to remove the DVD drive from the computer. First, unplug the computer after you have turned it off. Then remove both of the side covers. Most come off by removing the screws on the back that are holding the side covers on. Usually 2 on each side. The sides should then slide back and come off. Then you can see where the DVD drive is being held in, usually by 2 screws on each side. Remove those screws and unplug the power plug and the IDE cable from the back of the DVD drive and sometimes they have a smaller audio plug that needs to be removed as well. After you remove all of these the DVD drive should just slide right out of the computer case. Once the drive is out, look at the sides and the bottom. There are usually 4 screws that hold it all together, most often they are on the bottom. After you remove those screws you need to take the top cover off. After you get the top cover off, you can look for the object to be removed.
  • 2,336 Answers
If this DVD player is the one in your computer, it might be a bit challenging because you will have to remove both covers from the PC to get access to remove the DVD player. Once you remove the DVD from the PC, you will need to remove the lid from the DVD player to get that foreign material from it.
    Sergeant:
    Champion:
  • 347 Answers
You could try to open the DVD tray and place your DVD (with the DVD trayfacing down) and then gentylshake it untill theobject comes out.
You can also try to remove the screws (since i dont know the model of your dvd, i am guessing that you could turn it upside down and the screws will be there). Unscrew it andremove the object,
Good luck,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Nov 27, 2008
    To open the DVD tray, just click the button next to the DVD tray.
    PS. LAptop has to be on.
    To open your Acer safely you can register and then download the manual from this link:
    http://www.nodevice.com/manual/newmans/a...
    Good luck,
    Dahaka
  • 19,396 Answers
A new DVD dual layer RW for your desktop is just $25, buy a new one: Samsung SH-S203B/BEBN Dual Layer DVD±RW Drive
To Replace the dvd, see
How to replace DVD drive on Acer Aspire 300
  • 6,487 Answers
The only way that you can remove those foreign object inside the dvd player on your Acer Aspire M1610 is to take the dvd drive out and open it and that way you can remove those things....
  • 4,806 Answers
Unscrew the lid and remove it, then shake the dvd player softly and listen for where it is, quite often its a bit of plastic, so if you tip it upside down and give it a shake the object falls out and you can put it back together
regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    is this a laptop or a desktop please?
  • Lee Hodgson
    ok its a desktop, eject the tray, and power the pc down, remove all the leads including power, hold the pc with a very firm grip and shake it until the object falls out, dont worry about anyting inside the pc, you will have to drop it to do any damage,
    all you have to then is replace all the leads and your away
    kind regards
  • Lee Hodgson
    remember to have the front of the pc facing the floor with the dvd tray fully extended out
    Genius:
  • 1,550 Answers
From your statement i think there is some foreign object present in the dvd player . To take out the foreign material like bit paper , clips etc remove the top cover and look down inside to find the presence of foreign material .
This is initial help for further assistance post back more details like brand and model no of dvd player .
  • 1,879 Answers
If the object affects the dvd player's normal operation:
power off, unplug and get proper tools.
unscrew and gently take off the top case to have access inside.
check warranty before opening dvd player.
  • monk3ybidzness
    monk3ybidzness Nov 27, 2008
    FYI : Read Where You Posted Your Problem
    Generic problem for all DVD Players
    Should be posted under COMPUTERS
  • monk3ybidzness
    hope you got computer hardware skills
    try this first : stare at your COMPUTER's DVD Drive (the front face) and locate a small hole where a PIN would fit and press.
    else : power off and disconnect the computer power cord. look at the back for screws that hold the top case.
    if you manage to get the case cover out, you'll see the DVD drive and remove the small screws holding it in place. of course disconnect the cables inside connected to it.
    once you have the DVD drive out of the case, unscrew the DVD drive cover (screw's located the DVD's underside).
    just remember how you unscrewed everything, you'll need it.
    Sergeant:
    Champion:
  • 251 Answers
Take the screws out and get it out
My dvd is stuck inside the dvd tray, how do i remove my dvd from my naxa ntd 2256
I was not able to find the owner's manual on the manufacturer's website, so I'll make a general suggestion: look for a small hole next to the DVD slot (it may be at the end of the slot rather than outside of it). Straighten a paper clip, and carefully push it straight into the hole. When the paper clip wire touches a stop, push it a little bit further. If you feel it moving a part inside, you've found the emergency eject commonly incorporated into optical disk readers. Push it another couple of millimeters, and the DVD should pop out (if the DVD loader mechanism is not broken).
If there is a possibility that a small child has inserted a coin or other foreign object into the slot, you may have to remove power from the set, take the back off, then remove the foreign object. Otherwise, the DVD player will be unusable.
Aug 27, 2017 | Televison & Video
NO DISC ERROR
The drive cannot handle a cleaning disc, senses it as some foreign object.
Mar 26, 2014 | Sony DAV-TZ140 DVD System
I have a superscan tv vcr dvd combo and the dvd player makes a horrible screeching noise when i try to open it and play a dvd. Any ideas on how to fix this?
either some foreign object is also inside or a problem with the mechanism---someone would have to peek inside with it in operation to see (or in this case listen) to see where it sound is coming from.
Mar 19, 2012 | Sylvania Televison & Video
DVD player not responding. DVD stuck in player.
Possible failure of the loading or the disc loading mechanism. This needs to be checked only after you open the player and check for a possible mechanical jamming within the player. If so the disc could have stuck inside. broken or maybe with a foreign object.
If not manually turn to confirm on the motor drive to ensure that the DVD loads and returns. If this seems Ok then the motor or the motor drive circuit/IC needs a check.
Mar 26, 2011 | Televison & Video
EVERYTIME I PUT DVD,MP3,CD "NO
Hi Susan,
Your problem is in the lens assembly. First try to clean the optical lens by soft cottond buds. Dust build up and any tiny foreign object will block the lens from reading. If nothing happens, you need help from friends that can perform this steps http://www.fixya.com/support/r7833671-change_defective_motor_portable_dvd.
Hope it may help you.
Have a nice day!
Thanks for using fixya.
Feb 09, 2011 | Philips 7" Susan G Komen Portable DVD...
Dvd player freezes in the middle of a movie, the player stops and freezes on a scene
It sounds as if your DVD player is having trouble switching to the 2nd layer of the Dual layer DVD. If the DVD player is older, it may not even support dual layer DVD's. If it is a more recent model (less than a few years old), then the lense may need cleaning. You can try blowing the compressed air into the slot where the DVD goes (DVD removed, tray out if it is a tray model) or an inexpensive DVD lense cleaner you can find at most retailers (Wal-Mart, Target, etc.). The second layer requires a different focus on the lense and has to penetrate a little deeper into the DVD so it will be problematic if there is any dust or foreign objects on the lense.
Feb 01, 2010 | Televison & Video
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Dvd player says "no disc"
Could a foreign object have been inserted into the tray? I have seen labels peel off and stick inside the mechanism, preventing it from reading the DVD. Also try unplugging it from the wall, let it sit for a few minutes (for the logic circuits to reset) then plug back in. Just turning it off does not reset the logic...
Nov 04, 2007 | Daewoo DV-6T834 DVD Player/VCR
"BLOCKED" message
Solution 1: Most likely there is a foreign mechanical object obstructing the tray mechanism. If, like me, you have kids around every corner then most likely a curious little one has pushed something in to see "just what will happen". With some luck you can solve the problem by opening up the unit (power-off, unplugging first, of course) and doing a visual inspection for what shouldn't be there (pieces of paper, coins, toothpicks, fibres, etc).
Alternative Solution 2: Sometimes what happens is that the tray loading belt slackens over the years (age, humidity, over usage) and fails to respond quickly enough. In the absence of any obvious foreign object(s) this is a likely alternative explanation. Drive-tray electronics (called SERVOS) are programmed to expect timing signals to come within well-defined intervals of time. If this does not happen (such as due to a slack belt), then the condition is registered as an error. Try replacing the belt if solution 1 does not work.
Sep 26, 2007 | Yamaha DV-S5450 DVD Player
Audiovox D1708
Look for dust, dirt or foreign object on the laser lens under where you put the disc in. Maybe blow some clean air on it.
Feb 27, 2007 | Audiovox D1708 Portable DVD Player
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
