Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I am not getting any water to come out of the floor part or tools
The flow indicator is also not spinning, both tank and smartmix tank are full. I did open the top to fix the ready tool dial, because little piece that makes it switch from floor to tool broke. I am not sure if the pump is out or what. Please help!
  • 3 Answers
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
He filled the reservoir, turned on the switch and pressed the handle to get soap and water and nothing came out does not spray
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
WATER WILL NOT COME OUT
Nov 22, 2010 | Bissell 7901-R Clearview Proheat Plus...
My bissell wont release water or cleaner
Nov 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My bissell isnt putting down any solution or water
Oct 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My machine is not putting out water or sucking anything up
Please try these suggestions to get your machine working properly:
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Sep 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
It wont spray the water on the floor.what do i do
Try these suggestions to get your machine working properly:
Aug 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
IT will not put out or **** up water
If these suggestions do not resolve your issue contact BISSELL Consumer Services for further assistance.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have Bissell 7920. The water is not being
Jul 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Sprayer not working
If these suggestions do not solve the problem, contact a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Jun 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
464 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
