Question about Kenmore 42161 / 42169 Electric Single Oven
Control panel on my kenmore oven says f2 and fau le
Does this mean it needs servicing ? and what kind ? i flipped the breaker as i couldnt get it do anything from the control panel . it appears that it may have reset itself,. just before this happened i burned some dinner in it. could that have triggered somethhing ?
catriver
  • 878 Answers
SOURCE: oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Posted on Apr 22, 2007
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
aborcass
  • 2651 Answers
SOURCE: oven
F2 is aproblem with the oven sensor part number WB21X5301
Posted on Mar 16, 2008
SOURCE: Kenmore oven clock control installation instructions
powerman's solution worked great. It took me about 10 minutes. Just needed a sheet of paper, scissors and a philips screwdriver!
Posted on Jul 06, 2008
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
Why kenmore oven code f-10 comes on when bake or broil is on
I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
It should ohm out at 1100 ohms at room temperature.
If that checks good, then your control board is the problem.
Here's the oven sensor probe for your model:
Part#316217001show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
yNjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Here's your control board:
Part#316418208show?id=yo6223wzsty&bids=122738.582384825&type=10&subid=
0NjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Aug 20, 2014 | Ovens
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
Nothing happen what should i do now? i try to unlock and is nothing on the screen is black and by the screen with tha clock say F2;E1
If your oven is displaying the F2 E1 error code, then the problem is probably NOT just that the CONTROL LOCK feature on the oven was engaged.
The F2 E1 error is probably an indication of an electrical fault inside the electronic control system for the oven.
Sometimes this is simply a temporary error in the control panel circuitry which can be cleared by shutting off the electrical power supply to the oven for a minute or so at the breaker box.
Other times this is caused by a loose wire or faulty connection inside the control panel, or it is simply a faulty control panel circuit board.
Try switching off the electrical power to the oven using the corresponding breaker at the main fuse panel in your home. When you switch the power back on after a minute or so, press the CANCEL button on the oven controls panel.
If the above procedures do not work then you will likely need to contact a local service technician to disassemble the oven, diagnose the cause, and repair the problem.
If your oven is new, be sure to contact your dealer at the place of purchase since the cost of the repair may be covered under the terms of your warranty.
Good luck.
Joe.
Nov 03, 2011 | KitchenAid Ovens
My top oven is displaying some kind of error message. First it was F3, now it is F2. a loud ding noise comes with it. Help!!!
I get this, and F7 sometimes, especially after self-cleaning. Was told by a repairman to turn off the power, the breaker in electrical box and leave off. I usually leave off for anywhere from 5 hours to the next morning and then flip the breaker back on. Then it is fine. Happened to me 4 days before Thanksgiving too!
Nov 23, 2010 | DCS (WOTD-227) Double Oven
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
Hello. I have a Kenmore Ultra Bake, with push button control. After wiping down the panel it went crazy. The panel is now showing EO F2 and continuously beeping. I can use the stovetop, but can't turn...
Hi
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Kenmore Ovens
Kenmore electric oven will not turn on.
burnt out fuses or flipped circuit breakers? burnt out elements? Fuses are usually in the top of the oven above the knobs. Is it just the oven; check the main circuit panel? details?
Dec 28, 2009 | Kenmore Ovens
GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
May 26, 2009 | GE JRP15 Electric Single Oven
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kenmore 42161 / 42169 Electric Single Oven Logo
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
