Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony Wega, 60" LCD
Try to turn on set the indicator blinks 5Xs green and then proceeds to blink 6Xs red, I have already replaced the lamp, could someone please help me in this matter, my warranty has expired.
  • Sony Master
  • 5,138 Answers
I hope you know the light engine to these sets cost 1,900.00 up to 2,500.00 also did you reset lamp timer when you installed new lamp to tell set lamp has 0 hours on it?
Posted on Nov 27, 2008
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
I have a SONY Grand WEGA HDTV 60 inch LCD projection tv and the screen turns black, the power/standby green light(not the lamp) flashes about 38x then screen turns back on and off again every 30 seconds....
It may have a bad lamp--life is 2,000 hours so if it has not been replaced in a long time--some lamps will just before total failure do odd things.
A suggestion if you have not tried it---unplug set for a hour or so and plug it back to see if it will reset and resolve the issue.
Understand these sets have a shutdown feature that if something is wrong USUALLY on the front the red light will blink a specific code of up to ten blinks----
This is an error code and indicates general area of problem---if you do not have that---the set may be blinking as it attempts to fire the lamp up.
A clue that would point to the lamp is before it failed was it a bit darker the last few times it came on?
to post more information or ask something press the "make a comment button" on this page.
Mar 25, 2012 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Mar 28, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I replaced the lamp and it still doesn't work
You can try to reset the lamp timer. Check your manual to see how. If that doesn't help, your power supply may be bad. Then you should seek a repair service.
Feb 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
253 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
