Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Netgear wg111v2 wireless usb adapter wont acquire ip address
The adapter is the netgear wg111v2 usb type. i have installed the config utility and everything but when it connects to the router. everything is ok, the wep key works...i can connect. it just gives me all zeroes for my ip address. it wont acquire one for some reason. any help anyone?? im using windows xp pro on an ibm thinkpad t43p. ive also tried using the wireless program with microsoft and the program or utility with netgear. both have connected with the router but have been unable to acquire an ip address. PLEASE HELP!!
  • usmarine1886 Nov 28, 2008
    i know where all of that is. ive also taken the same settings from the local network connection that was with the ethernet connection and applied them to the ip protocol for the wireless connection. i know the routers ip address. ive used one of the allotted ip addresses from the range ive got set for computers on this network. the last octet in the ip address. i use these settings here and it still says its trying to acquire ip address. so it sees the router or access point but it never gets an ip address assigned from the router. im starting to think there is something wrong with the router. but then i tried connecting to a different router in the area and it does the same thing. not sure if its the usb adapter or router now. but i know the wireless adapter picks up signals and makes connectivity...just doesnt get an ip assigned. gateway is set up correctly and the dns addresses are correct. thanks for the help though
    Scholar:
  • 65 Answers
Not sure if this is where you are looking, but it probably is. click START then CONNECT TO then SHOW ALL CONNECTIONS then right click LOCAL AREA CONNECTION click STATUS then SUPPORT,,,
or CONTROL PANEL then NETWORK CONNECTIONS then right click LOCAL AREA CONNECTIONS then click STATUS then SUPPORT tab
See what you have there for an IP address
Is it the computer you don't have an IP for or the router? In my case my computer IP the 8th or last digit is the next number after what it is for the router. The other numbers are the same
Posted on Nov 27, 2008
  • hdpanama
    hdpanama Nov 28, 2008
    Just in case you might have OneCare installed, I found this info :
    Configuration
    • Windows XP Pro connected to router/wireless access point (WAP) as OneCare Hub via ethernet
    • Wii, iPod Touch both connected to wireless network
    • Windows XP Home desktop connected to router/access point as a non-hub member of OneCare circle
    • WPA TKIP security
    Problem
    • The XP Home machine will sometimes be unable to acquire an IP address from the router/WAP
    After
    trying many things, I've found that uninstalling OneCare will allow
    this machine to obtain an IP address (192.168.1.x) and rejoin the
    network. I then reinstall OneCare and the problem goes away...for
    awhile.
    Once the problem only went away for a few days -- other
    times the problem goes away for weeks. However, as soon as I see the
    sytem tray icon animating the "attempting to acquire an IP address" I
    know what I'm in for -- uninstall/reinstall OneCare.
    BTW, I know
    that it's not the rebooting that's fixing the problem -- I tried that
    many times before resorting to an uninstall/reinstall of OneCare.
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Tip
How to Install WG111v3 on MAC OS 10.3 , 10.4, 10.5
<p>The below article would illustrate the steps to install the NETGEAR wireless adapter WG111v3 on MAC OS 10.3, 10.4 and 10.5.<br /> <p><br /> <p>Please ensure that you have installed the latest version of driver for the adapter from the below link on your MAC OS computer:<br /> <p><br /> <p><a href="http://kb.netgear.com/app/answers/detail/a_id/2640">http://kb.netgear.com/app/answers/detail/a_id/2640</a><br /> <p><br /> <p>After the installation of the driver please perform the below task:<br /> <p><br /> <p>1. Plug in the adapter.<br /> <p>2. Double click on the NETGEAR WLAN Client Utility in the desktop.<br /> <p>3. On the NETGEAR WLAN Client utility select the Available Network tab which will detect the wireless network, select your network and click Connect.<br /> <p>4. If you are connecting to a secured wireless network then you will be prompted for a Wireless Network Security Properties menu.<br /> <p>5. Type the network key WEP/WPA security and click OK.<br /> <p>6. Click on Link Status which shows the connection as connected.<br /> <p>7. Check for the IP address by clicking on the Apple icon and select System Preference.<br /> <p>8. Click on Networks and check the IP address.<br /> <p><br /> <p>You should have succesfully established the wireless network on your MAC.
on Mar 24, 2011 | Computers & Internet
Re set wireless usb adapter
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
May 18, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Wireless connection
JRSavage - The solution you supllied is to assign the IP address to the client. It appears Guest is asking how to log into the Router.
Guest - If the router is a wireless router then you should not have to know it's IP to connect to it, simply looks for it's SSID in WIndows Zero Config wireless util (or the util that came with your wireless adapter)
If you're connected and looking how to log into the router itself you'll want to enter the router's IP address into the address bar of your internet browser.
If you're looking for where you enter the router's IP for NIC configuration, you would enter the Router's IP as the Gateway address.
Feb 23, 2008 | NetGear WGR614 Wireless Router
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
819 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
