Question about Cameras
I have the sony DSC-N2, it will not let me take a picture or video. When i put it in these modes, the screen is completely black but says "turn the power off and on again". When i do that it does nothing different. However, i can access my photos and albums. please help, i need my camera!!!!
Posted on Jun 02, 2009
  • 38 Answers
LENS section is faulty and have to be replace to solve this problem.
Posted on Nov 27, 2008
I get (have) a black screen when I put my camera in the on position to take picture/video. I can view all pass picture/video, If I switch mode to view. when I switch the mode to take picture or video I...
Try hitting the display button(the small TV resembling icon in the bottom right of the camera). You may have accidentally pressed it while using your camera and caused it to turn off your display.
Mar 07, 2011 | Sony Cyber-Shot DSC-M1 Digital Camera
Sony dsc-n2 my video mode is not working properly and also its turn off suddenly
The Camera will turn off or will not allow selecting the Movie Recording option when the Battery power is not enough. Please make sure that the Battery is fully charged. Make sure that the battery inserted is NPBG1. You may also try cleaning the terminals of the Battery pack. If the issue persists, try using a different battery pack. If the same happens again, service may be required.
Thanks,
KenSolutions
FixYa
Oct 22, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Turn off and on again.
you should have dropped your camera down hard. you should replace your lens array from the nearest sony service center. it costs about 60$.
Jun 11, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
All pictures taken are just Blackness
is there a view finder on this camera? often when there is a screen and a viewfinder there is a button to toggle between them, my sony camera has such a button although it is not a cybershot. i imagine the button says "dis" or "LCD" and just needs to be toggled. if the display were bad you would not be able to view pictures on it. display works must be configuration issue.
Jan 05, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Sony DSC T300. Problems with the flash
Hello!
I just solved this problem: to put flash, while you are in shooting mode, touch MENU, then REC Mode on the first page, and touch Normal, to take a single picture and then OK, you'll have the Auto Flash which appeares; but I never knew how to put the other kinds of flash...
Nov 03, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony N2 veiwfinder problem!
Can you see Shadow images[ indicating back light failure]
or Nothing at all[ Indication main circuit board or connector problem
If you are still in warranty then send it back to seller.
You could try gently squeezing the case below the screen to see if there is a chance of a re connection.
Also check out Sony support in case there is an issue with that model
Failing that it is a repair job
Prbably nearly as expensive as simply junking it and start over
May 07, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Cameras Logo
124 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
