Question about Tomtom ONE GPS Receiver
Frozen screen I have a tomtom one the screen just froze. I have an orange screen with TomTom one and it will not turn on or off. I connected it to USB port but it cannot be found by the computer
  • Anonymous Mar 20, 2009
    I have a tomtom one the screen just froze. I have an orange screen with TomTom one and it will not turn on or off. I pressed the reset and when I turn it on again -- it's just the same screen.
I have had a frozen screen on my TOM TOM - I solved this problem by resetting the TOM TOM. I did this by pressing the pinhole reset buttom on the back of the unit - labled RESET.
Posted on Nov 27, 2008
TOMTOM GO LIVE 1000 Orange charge light will not
The battery is stuffed and needs replacing. It is a well know issue.
Aug 28, 2013 | Tomtom One Europe v2 GPS Receiver
I have a tomtom one 2nd edition. It is frozen on.
Easy, simple take a pen and press the reset on the bottom of the Tomtom, just like any other electronic device.
Dec 30, 2008 | Tomtom ONE GPS Receiver
My tomtom receiver is frozen on the start screen.
Connect your TomTom to the USB cable then turn on your TomTom in that order. Go to "My Computer" and open the drive that is your TomTom. Copy and paste your map folder to the desktop. Delete everything on your TomTom (don't format). After deleting everything on your TomTom. Open TomTom Home. TomTom Home will tell you, you need an application for your TomTom. Let TomTom Home load the application. You will probably have to do this at least 2 times to get the latest application for your device. After TomTom Home has loaded the latest application for your device closer TomTom Home and copy and paste your map back onto your TomTom. You should be ready to go after doing this. Make sure you do not skip a step when doing this.
Dec 27, 2008 | Tomtom ONE 130 GPS Receiver
The screen is frozen and will not turn off. If I reset it, it won't move pass the first screen.
A little trick:
1. Make sure the device is off and connect it to your computer via USB (green light should be on)
2. Hit the reset button on the bottom.
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 11, 2008 | Tomtom ONE 3rd Edition GPS
Frozen tomtom go 910
Hi, Not a nice problem that. Try connecting your tomtom to PC ( not through home ) so the tomtom will look like a USB drive in "My Computer". if TomTom Home tries to load up , cancel it. Look in "My Compuer" If you do see the TomTom as a drive , open it up and copy the folders and files to your PC. If that works, now you have a backup and you can have a mess around knowing that if you mess things up , at least you can put things back as they were and you won't have made anything worse than it was before. Once thats done , try a harder reset in normal way but also hold the ON button in whilst doing the reset . Many people press too hard on the reset button and also hold it too long so just give one single press , only hard enough to feel it click in , then out. Thats all it needs for a reset and it avoide damaging the switch ( yes , I have seen many reset switched stuck in or broken ). I think theres 2 possible causes for your problem . 1/ You now have a corrupted file on your TomTom preventing the boot-up continuing. 2/ Your Tomtom is still trying to perform the last function ( backing up through TomTom-home ) and has somehow got stuck in that loop. For the moment , try the above and see how you get on and if you donn't solve it please post on this forum again .
Good luck .
Nov 12, 2008 | Tomtom GO 910 GPS Receiver
Frozen
Hook the Tomtom using the USB cable to your computer4.gif. You should see the Tomtom drive under My Computer as a drive letter.
Backup1.gif all data1.gif from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Jan 04, 2008 | Tomtom GO 910 GPS Receiver
Frozen 910
http://www.gpsmagazine.com/2006/06/tomtom_quietly_releases_firmwa.php?page=all
Dec 09, 2007 | Tomtom GO 910 GPS Receiver
TomTom frozen
My TomTom One is acting up. All of a suddent, it has a hard time finding a valid GPS signal. Then, it sometimes becomes frozen at the first screen when you turn it on. When I try to connect to the computer, the menu page comes up on the computer screen, but the unit does not respond to anything. This unit has operated smoothly until now and I have done nothing to change it. Any ideas?
Dec 01, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
392 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
