Question about Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool RF363PXDW electric stove
Latch door light contiuosly flashes..door will not latch can not pre heat, bake or cook. oven does heat up if in clean mode
SOURCE:
SOURCE: locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Posted on Nov 04, 2006
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
my oven door wont open since i self clean it
Posted on Nov 10, 2008
SOURCE: Whirlpool eletric range model RF363PXDW w/F1 display
The manual to this oven is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
That should fix almost any problem you have
Posted on Apr 03, 2009
Oven will not maintain heat
possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
Feb 28, 2018 | Whirlpool Ovens
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
Mar 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
Whirlpool GS475LEKS Gas Kitchen Range Logo
101 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
