Hi, I have an Hitachi 51F500 projection TV. I appear to have a convergence problem of some sort. The blue is off by quite a bit. I tried magic focus and manual convergence w/ no luck. When I unplug the component input b (of rby) I get no effect. When I uplug the others, the colors change. almost like the blue input is not registing into the TV. Same problem w/ DVD input and Dish input so I think it is a TV issue.
Comments:
Dec 02, 2008
- Ended up having a tech replace the STK 392-110 for blue. A resistor was also blown. Good thing I didn't try replacing myself.....not much experience w/ soldering on circuit boards.
- wondering why you gave me a rating of helpfull when indeed i told you extactly what was wrong and i am sure he had to replace 3 resistors that burn out of range low ohm 2.7ohm 3.3 ohm 3.9 ohm from now on i am not giving out any FREEE ADVICE>!!!!!!!!!!
how to hook laptop to my hitachi 51f500 tv fto watch movies. i am told i cant because the tv would...
(More)
how to hook laptop to my hitachi 51f500 tv fto watch movies. i am told i cant because the tv would be grainy. is this true and if not, exactly which cables would i need. thank you
After turning on our TV, we just see a blue and gray striped screen. We had this problem before a...
(More)
After turning on our TV, we just see a blue and gray striped screen. We had this problem before a few months after we purchased the TV (6 years ago).
TV was doing the below on and off, not every time it was turned on. Then today the red power button...
(More)
TV was doing the below on and off, not every time it was turned on. Then today the red power button just makes a chirping sound while it blinks and there is no picture on the tv. Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu.
