Question about GE JGBS23 Gas Kitchen Range
JGBS23 oven ge bought new ignigtor oven comes on but flame is high and can,t adjust with oven control knob. does not move flame up or down.
  • 1,147 Answers
Regulator controls flame
Posted on Jun 20, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Dec 01, 2010 | Ovens
OVEN TEMPERATURE TOO HOY
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
Can,t adjust flame in oven
flame is adjusted threw your regulator.
Nov 27, 2008 | GE JGBS23 Gas Kitchen Range
Parkinson cowan sonata 55x gas cooker
When foods come out burned, soggy, or unevenly baked, it generally means heat isn't being distributed evenly throughout the oven, it's escaping out the door, or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven.
2) Check the door gasket, and, if necessary, replace it.
3) Be sure nothing is obstructing the vent.
4) Reposition the oven racks so baking pans aren't too close to the heat sources.
5) Check your baking pans. If they're dark, they may be burning your food. Reduce the temperature by 25 degrees Fahrenheit when baking in dark metal or glass pans.
You can also recalibrate the controls. If your oven has calibration right on the knob, you can calibrate the appliance as follows. If it doesn't, call an appliance repairperson. To adjust the thermostat's calibration:
1) Remove the oven temperature knob by pulling it off its shaft.
2) Notice the current setting, and then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer on some models; if this is the case, you'll have to remove a couple of screws. Figure that moving it one notch will change the setting by 10 degrees Fahrenheit.
3) For more accurate calibration, call an appliance repairperson.
Do rate the solution i need it!!
Jun 17, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
GE JGBS23 Gas Kitchen Range Logo
146 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
