I have a philips hdd gogear 065/05, and i was wondering if anybody knows how to get the songs to play back at full volume through an auxilary cable. a friend at work has an ipod, and when they play it through the sound system at work, the volume is loud enough to hear. however, when i play my hdd, i can barely hear anything. do i have to do something with the hdd, is it something that i can change through the songs, or is the hdd just like that anyways??
thanks for the help!!
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
This could be a feature which does not encourage the full sound option as it might drain off the battery in less time. Hence it is to be used only in cases where the need is necessary and so you need to manually select the song or skip before it selects by itself as the volume level can be retained.
PLA - disconnect hdd from computer, reset the player by holding play and volume + at same time, then reconnect the player; if that doesn't work, write me back
Cynthia - use Windows Media Player to transfer songs - if you get an error message or run into snags, write me back
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard). -Tha Mp3 Doctor
