Question about MGE 400W Power Supply (QG) Power Supply
What is a good replacement for the MGE 400W
I need to replace my MGE 400W due to failure. What is the easiest swap.
  • 1,183 Answers
You can buy checkout the following link for brands and prices of different power supplies.
http://www.dealtime.com/xPP-power_suppliers--350___450_watt
What is important to check , does the power supply have the same wattage, and power connectors . Before buying kindly check
1. If you need SATA power cable connection on your new power supply
2. If you need additional power cable connection for the video card
Thanks
proton
Posted on Nov 27, 2008
  • 4,806 Answers
All you have to do is swap it with another one with the same specs connectors and wattage, thats a good PSU, i'd replace it with 550 wats
    Sergeant:
    Champion:
  • 251 Answers
Buy one at a local computer store
Internal fault 02
inverter fault power board must be replaced
Jan 17, 2013 | MGE UPS Pulsar EXtreme 3000 VA Hot-swap...
MGE UPS Tuner softwares
My dear i think there need to upgrad/re-initialized its battery life from ups tuner.
i have mge ups tuners for all models
Regards
techdata41@gmail.com
Jul 28, 2012 | MGE Galaxy 3000 UPS System
We at CAAP Davao Philippines have a MGE Galaxy 3000 10KVa UPS with serial no. 13299-4. It was installed last 2003. We had three times replaced its batteries over the period of years, the latest was 2008....
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
Apr 01, 2011 | MGE Galaxy 3000 UPS System
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 25, 2011 | HP ATX-400W, ATX-400W Rev. T1, HP P/N:...
Why power supply did not work
You didn't include any additional details about your power supply so the reason that it's not working could be one of several.
I assume you're plugging this into your motherboard correctly. Make sure the main connection pins are lined up correctly. In truth, you shouldn't be able to do this incorrectly due to it only allowing it to be inserted in one direction. Another note, you can't just plug it into the wall and expect the fan to go when the circuits aren't complete (i.e testing it outside the computer).
In newer systems that is an additional 4 prong plug wire that needs to be attached to the motherboard, in addition to the 20 prong (the only BIG one) plug
Lastly, power supplies are very cheaply built, so it's also possible it has just died. You didn't mention that it was working originally either, so I don't know if it not working is a new thing.
I usually get a 'good' one (higher wattage, 600-750W or more) and reuse these from system to sytem. What's a good one? Well, that's up for discussion, but one that feels heavier, has detachable cables, and dual 12v rails. These are the features I like to see. The higher initial investment easily pays for itself over the longer lifetime.
Jul 27, 2010 | MGE 400W Power Supply (QG) Power Supply
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Aug 13, 2009 | MGE UPS Pulsar Evolution 3000 UPS System
Power Supply Replacement
It never hurts to have a larger power supply, yes it have use 100watts more in a hour. But you should have better reliability with the 450W.
Mark
Apr 05, 2009 | Computers & Internet
I need a new power supply
It's not more than 1yr and you would need to be the original purchaser with a receipt. MGE does not allow owernship transfers on warranties.
Nov 27, 2008 | MGE 400W Power Supply (QG) Power Supply
MGE 400W Power Supply (QG) Power Supply Logo
144 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
