Question about Jenn-Air Kitchen Ranges
My meat probe buzzer cannot be turned off. - Jenn-Air Kitchen Ranges
  • Anonymous Jan 22, 2009
    the Jannair oven buzzes when the meat probe is unpugged.
I had the same problem and fixed it by simply turning off the power at the breaker for 10 minutes and then back on. At first, I just flipped the breaker off and back on, but it still kept beeping. Not until i let it stay off for a while did it 'reset' and stop beeping.
Posted on Jan 05, 2010
  • Gabrielle Rogers Dec 05, 2011
    Thank you for your answer!
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 | Ovens
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
My meat probe on my jenn-air electric stove works but no beep
you may need to scroll through your settings to turn the beep on
Nov 25, 2008 | Kitchen Ranges
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong?
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Aug 16, 2008 | Sunbeam 4214 Iron
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
272 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
