Question about Microwave Ovens
I have a ge microwave jes1289sk01 and it is sparking
Can i just replace the cover wave guide or do I need to replace the magnetron also?
  • 1 more comment
  • videoflix01 Mar 07, 2009
    I also have this issue. I called GE for service and it is $90 just to come out. Don't know if it is worth trying to fix or something we can do ourselves, but $200+ to buy a new one when this is only 1 1/2yrs old(should last longer then that. when using it the lights flickers then a shorting sound comes from right side panels such as an elkectric shorting sounds and sparks thru that vent on top right side. Is there any way of fixing this ourselves or should be just take the loss and move on?
  • William Miller
    William Miller May 11, 2010
    If there's nothing wrong with the magnetron, yes.
    What problem are you having with the oven?
  • Adam Jerome_lagudi
    Adam Jerome_lagudi May 11, 2010
    is the wave guide damaged or is the unit not heating?
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave replacement magnetron
At first I was concerned but then I realized what it was.
Congrats on their sending you the mag!
How did you convince them to do that? Did they make you sign a waiver?
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sparks from the interior of the microwave
Quiteoften this is due to grease or food particles stuck somewhere in thecavity of the oven or stuck on or behind the waveguide cover.
It can be fragile, andthe metal edges of the oven behind it can be sharp, so be careful!
The cover and the metalbehind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal ofthe oven is chipped or charred, it will have to be sanded smooth andclean and dried thoroughly.
Then you can apply somehigh-temperature appliance paint, available from places like Wal-Mart,Lowe's or Builder's Square.
If your waveguide coveris burned, it will need to be replaced. It provides importantprotection for the magnetron.
You can findhelpful exploded view diagrams and order parts by entering your fullmodel number here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
Posted on Jan 18, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 03, 2009
  • 17 Answers
SOURCE: Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Posted on Feb 08, 2009
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cover or...
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape.
Apr 17, 2014 | Maytag MMC5000 Microwave Oven
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
Sparks from wave guide
the magnetron may have burnt itself up. it may be time to replace
Nov 05, 2013 | Microwave Ovens
Microwave sparking
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 29, 2013 | Bosch 500 HMB5050 Microwave Oven
WE HAVE A KUPPERBUSCH MICROWAVE WHICH HAS STARTED TO SPARK WITH A STRONG SMELL OF ELECTRICS BURNING INSIDE IT WHEN TURNED ON. WOULD LIKE SOMEONE TO LOOK AT IT. WE LIVE IN CO. ARMAGH, NORTHERN IRELAND AND...
Somtimes the wave guides with food particles can burn and smoke if so replace the wave guide.
Also remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Jul 27, 2011 | Microwave Ovens
My built-in microwave, 2001 build UMC5100ADW emits sparks from behind cardboard panel. Suspect magnatron, or maybe metal deposits in cardboard. Looking for a replacement to fit the frame...
That "Cardboard" item is a wave guide cover and is critical part of the machine.
It is made of mica and needs replacing. The magnetron is OK as long as it does not spark too much or get any foreign items in there.
Replace the wave guide cover.
Feb 27, 2011 | Maytag Microwave Ovens
Have a ge microwave jes1289sk01 and it is sparking from behind the small fiberboard just inside the right side of the interior of unit. I removed fiberboard and sparking stopped. Unit still heats. do I...
That small card prevents food particles from entering Magnatron but allows RF energy to pass through. The corrosion mentioned is the result of the arcing. Just replace that protector. It will be specific to that brand and model.
Nov 14, 2017 | Microwave Ovens
Clicking When Unit Starts
Q - When there is small amounts of food in the oven, arcing occurs right behind the plate where the wave guide comes into the oven. Sometimes it works well and sometimes you can't even put in a bag of popcorn. Any ideas? Could food have 'dripped' in here and be causing a microwave short?
A - Yes! Food splatter or drips can continue to cook and will carbon over creating sparks/arcs from the wave guide cover. Usually can clean up the food on and under the wave guide cover, if the oven liner has been damaged we usually lightly sand and touch up those marks with touch paint. Do not let it go for too long as damage to the magnetron end is possible as well :(   If the wave guide cover has been damaged, replace it!
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Over the Range Microwave Oven
sandy, i think your magnetron just went bad. can you see if there is a black spot or dirt accumulating on the microwave guide cover. it is the gray rectangular thing at the side of the wall . these black spots are from oil or food that have accumulated and has been heated over and over again untill it becomes carbon and becomes conductive. these carbon then conducts electricity to the metal casing holding the wave guide cover. if this happens, the tip of the megnetron would spark against the wall and burn the tip of the magnetron and short it out. if it has a fuse, it could pop out and might still save the magnetron. if there is none, then you could have end up with a bad magnetron. decide how much a magnetron first before you buy a new oven. i hope i was able to help.
Jun 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
261 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
