Question about Casio Exilim EX-Z57 Digital Camera
Does not read memory card
The card is formatted it is not locked and tryed multiple brands of cards.The camera still just runs off of internal memory even when a card is inserted
  • 374 Answers
Casio only tested 3 cards with the camera. Sandisc, Toshiba, Panasonic. First: Format the internal memory of camera and then reset camera. In rec mode press menu go to setup tab go up to format press right arrow highlight format press set. Follow same steps for resetting. Then insert mem card and format mem card. If that still doesn't work I would say there is something wrong with the camera itself and would need to be sent in.
Posted on Jul 10, 2007
Camera will not format sd card nor does it show a card in the camera
Something tells me that you're trying to use a brand new 4GB SDHC card. If so, your camera was designed before SDHC format came out. You'll need to use standard SD cards, those 2gb or less. Search on Amazon for "SD card 2GB". They run about 6 to 7 dollars total with shipping.
For others with similar problems, There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Samsung NV3 Digital Camera
I have a Canon A400 that is displaying the common 'memory card error' message. I've been through most of the tricks that I've found on the Internet but still no success. Tried multiple memory cards,...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you are indeed using 2GB or less cards (as you should be for your older A400), then give the toothpick fix a try listed in the above link.
Mar 05, 2011 | Canon PowerShot A400 Digital Camera
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 27, 2010 | Jazz DV-179 Digital Camera
Canon PowerShot SD400 No memory card message, but there is a memory card installed. Tried multiple memory cards and got the same message. Made sure the memory card was locked.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you're using 4GB or larger SDHC cards, they won't work with the SD400 as that camera was made before SDHC came out. Consider 2GB or less standard SD cards only. They're very inexpensive these days on Amazon..
Dec 27, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera wont read memory card error message say: memory card error, please check the card. I dont think its the card becaouse other devices can read it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 17, 2010 | Panasonic DMC-TZ5 Digital Camera
Brand new memory card
I have the same problem with the same camera. I checked other sites and it seems that the C330 takes only SD cards up to a max of 1GB. It won't read SDHC cards and it won't read SD cards greater than 1GB.
Jul 03, 2010 | Kodak EasyShare C330 Digital Camera
My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
Mar 01, 2010 | Pentax Optio M20 Digital Camera
When I turn on my DMC-LS75, it displays this message:Memory Card Error - Please Check The Card. HOWEVER, the same card can be read in my computer and can be used in another digital camera.
Never heard of that brand name, all memory cards work by the same set rules. Check to see if memory is installed wrong. Check to see if it is compatible with your camera. Inretrospec, I would have to suspect it's a bad PCB in your camera.
Aug 06, 2009 | Panasonic Lumix DMC-LS75 Digital Camera
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Nov 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
209 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
