Question about GE JGBS23 Gas Kitchen Range
Can,t adjust flame in oven
Bought new ignitor for JGBS23 oven comes on but can not adjust flame. flame is high
  • 1,165 Answers
Flame is adjusted threw your regulator.
Posted on Jun 20, 2009
Can I adjust the regulator to lower the flame?
Hello Douglas;
My name is Peter. I am a retired field service appliance technician.
What bothers me is that changing these components increased your flame size?
1.) Make sure you have the correct gas safety valve. These valves are preset to inches of water column.
2.) The ignitor has nothing to do with your flame size. What happens is the oven thermocouple controls your oven temperature. When your oven get about 40 degrees above the set temperature, the ignitor and controlling gas components will shut down. When your oven temperature falls below the set temperature the ignitor and gas components will turn back on. There are ovens called accurate, which are expensive and do not have a 80 degree swing.
3.) Ok. Gas regulator. It is adjustable. Generally you have about a 7" water column pressure going into the regulator and 1" to 4" water column pressure coming out.
At the top of the gas regulator you have a long stem. Inside this stem is a shaft with a spring at the top and a valve at the bottom. In between is a rubber diagram which controls the valve based on the gas inlet and outlet pressure.
4.) Adjust. Turn the gas supply off to the range. Turn on the oven and gas burners to bleed the gas from the system.
There is a slot at the top of the stem. With a flat head screw driver, turn the stem top 1/8 of a turn counter clockwise to reduce the regulator outlet pressure. Turn the gas supply back on to check the flame. You may have to repeat this process to get your desired flame.
BE PATIENT. BE SAFE.
Mar 03, 2016 | Frigidaire Kitchen Ranges
I have a kenmore gas stove 790-75711890. my oven ignitor was only glowing. so i thought not enough gas i removed pressure regulator and blow thur it then reassemble. still not liting. i bought new oven...
On the top of pressure regulater is a removalable piece that fits one way for nautral gas and the other way for propane i am wondering it was installed upside down afer ya reassambled it, accidenttly setting it to propane which defeintly will cause that
Aug 22, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven won't come on. It's gas stove. I don't see where the pilot light is. The light comes on when I turn the know to BAKE but the oven never gets hot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 25, 2011 | GE JGBS23 Gas Kitchen Range
Oven will not heat
Hi.
Check if flame is turning on. If there is flame but no heat, then the most common fault is the temperature probe sensor, located inside the cavity.This will affect both broiling and baking function.
If there is no flame check if the glow bar or spark igniter is working. If ignitor is OK, test the valve coils. The coils are tested using a multimeter set on Ohms on the coil contacts. If the circuit is open (no continuity-Ohms infinity), then the coil is bad and must be replaced.
Other part that may result in no flame is the flame sensor. this fault is less common.
Check also gas pressure and pressure regulator if present.
Regards.
Ginko.
Jan 03, 2011 | GE JGBS23 Gas Kitchen Range
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
How do i change the oven ignitor
The following link gives you step-by-step instructions on how to replace an igniter in a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions about this repair, please let me know. I hope this helps you.
Nov 25, 2009 | GE JGBS23 Gas Kitchen Range
OVEN TEMPERATURE TOO HOY
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Jan 18, 2008 | GE JGBS23 Gas Kitchen Range
GE JGBS23 Gas Kitchen Range Logo
488 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
