Question about Hobart A200 Stand Mixer
Hobart A200T - agitator shaft replacement
Hi Bigg T, I read through your other solutions - Kudos to you for being so helpful and valuable!!
The little key on my agitator shaft broke off, so I am replacing the entire shaft. How do I go about doing this? I have the assembly pics/parts list and I am wondering if I need to get at it from the top by removing the transmission? Or can I get to it from the bottom? THANKS!!
  • 2 more comments
  • leftychang Nov 27, 2008
    i found that a little key is holding it in place on the center shaft ... how do i remove this key?
    a little more digging and i found this thing is called a "gib key" or "tapered key" and they make special removers for them ... problem is searching google has me coming up empty ... any idea where i can get this tool?
    or any other ideas on how to get it out? i read that some car guys weld a bolt to the gib key then pull it out, but id like to avoid pulling the TIG welder out for this one (if i can)
  • bigtex2 Feb 01, 2009
    my shaft broke and i need to know how to take all those gears apart
  • Jim May 11, 2010
    Hi, usually the key comes right out, do you have the planetary hub off already? and is the key split, meaning did it sheer in the shaft?
  • 135 Answers
Lefty, It's called a tapered pin. It can be removed by using a punch which is a bit smaller than the pin. This tapered pin can only be driven out from one side. Put a bit of WD-40 or some other penetrating oil in the pin area then figure out which end of the pin is smallest. Gently tap it out with the punch and a hammer, only use as much force as necessary. Only replace the shaft if it's badly damaged. You may be able to get at it by removing the four screws on the attachment hub. Remove the hub and see if you can get at it from there. If you can't, you should be able to get at it from the top. If you do replace it, you might consider replacing the shaft bearing and the bearing on the planetary shaft. If you find this solution helpfull, please rate it. Good luck. ricardok45
Posted on Jan 05, 2009
Ae200 hobart mixer agitator beater shaft
http://thesmartpartsestore.hobartservice.com/
Sep 02, 2015 | Hobart Food Mixers
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
Hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Sep 25, 2009 | Hobart N50 Stand Mixer
Small screw and nut?
By turning the screw cw or ccw it adjusts the clearance on the worm shaft assembely,in other words if the mixer is noisy by adjusting this screw you can quiet it down.
Mar 30, 2009 | Hobart A200 Stand Mixer
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Gear problem
Sounds like a sheared key,explain your problem a little more i work for hobart.
Jul 26, 2008 | Hobart A200 Stand Mixer
Hobart 20 quart mixer
Hey tom dont worry about it.These mixers hold a decent amount of grease.If you need any other info let me know.
Jul 23, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
559 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
