Question about JVC GR-D73 Mini DV Digital Camcorder
It says lens cap is on when it isn't - JVC GR-D73 Mini DV Digital Camcorder
  • colemanj Feb 11, 2009
    It says lens cap is still on when it isn't. If I re-play something, I don't have problems viewing it, but when I attempt to record, it won't let me.
    Problem Solver:
  • 11 Answers
Manufacturer fault and was fixed for free but the free offer may be over
Posted on Dec 20, 2008
Remove stuck rear lens cap
The first thing I would try is using one of those rubber pads that are used for removing stubborn lids from jars. If that dose not work, I would use the fact that the Nikon rear lens caps are made out of soft plastic to my advantage. If you have a Dremel rotary tool with a disk cutting tool, you may be able to CAREFULLY and slowly cut away the lens cap. You didn't say which lens this is, but since with most lenses the telephoto position moves the rear element away from the back of the lens, I would set the lens to telephoto before starting to cut. I would start by cutting through the back of the lens cap. Cut a little at a time and try to take off the cap. Proceed slowly periodically trying to remove the cap. Hopefully, the pressure will be relieved and the cap will release before it becomes necessary to cut across the lens flange. When you are done, I would carefully clear the lens of any debris.
Jul 05, 2014 | Nikon Cameras
How to remove stucked lens cap
It depends what lens cap you have some lens caps you pinch off
Others you pull off some screw off its the easiest thing you can do on the camera you should have had a a1 filter screwed on before the lens cap then all you would have done is unscrew it all.
Then again you may have to take it to Nikon on Wilshire
Jun 08, 2014 | Nikon D3100 Digital Camera
Lens cap
place the lens cap back and then off the camera. after that turn onn agin and remove safely
Apr 25, 2013 | FUJIFILM FinePix S4000 / S4050 Digital...
Check fuel cap light
This typically means that your fuel cap isn't making a tight enough seal and the tank isn't getting pressurized as it should be.
Jul 11, 2012 | Cars & Trucks
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
I recently shot three rolls of color film with my ZX-7 in auto pict mode and all the negatives turned out blank (underexposed). What happened?
lens cap ? ;-]
Did you have the asa film speed set correctly? Thats usually the cause unless your battery isn;t quite right.
Mar 23, 2010 | Pentax ZX-7 35mm SLR Camera
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
JVC GR-D73 Mini DV Digital Camcorder Logo
170 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
