Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
WBR-2310 DLINK router is not showing in my wireless network list
Well, router LED's are glowing and blinking as it has too, but nw signal is not appear in my wireless n/ws...
  • Anonymous Dec 15, 2008
    I have rev_A with version 1.05 firmware. I have two desktops direct connected and 1 laptop wireless. The router peiodically stops broadcasting requiring a hard reboot of the router correcting the problem until the next drop. One desktop is XP Home the other two are XP Pro.
  • thebigshow Dec 29, 2008
    Im having the same problem I have one desktop with xp home direct connected and 2 laptops wireless with vista in one and xp in the other with version 1.05 firmware in my router. There is a beta version out and tryed it but it got worse started to stop broadcasting every 3 hours. I can connect with my desktop but thats it.
  • 3 Answers
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Posted on Jan 04, 2009
Trying to set up my wireless router
Here is a direct link to show you how to setup your router simply click product manual and it will auto download it for you thank you have a good day.
Jan 14, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
All lights on router WBR 2310,1st and 3rd blinking- our network doesn't show up in list to go wireless???
I will advice you to reset and reconfigure the router to refresh its settings. to reset it press and hold the reset button of the router for 10 seconds while power is ON and the reconfigure it back..........
Nov 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have a Gateway nv52 laptop and a dlink wbr 2310 wireless router. I can not connect to my network, but I can connect to my friends syslink. If I plug right in to the main motorola router, I get...
So that means you are able to connect to the network with the ethernet cable only.
Did yopu try to connect to the wireless network ?
And if yes then what was the error message ?
Click Here for more info about wireless connection. Pl. go through the web site you will get the answer !
Oct 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How do I reset my security with the dlink 2310
To change your router wireless security
  • Support site here
  • User guide here
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter the user name (admin) and your password. Leave the password blank by default. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 25 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops Wireless Profiles - Vista/Windows 7: - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Oct 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Need to re-set my ssid network name to re-secure my wireless network
Some support information for your router can be found at dlink site:
type wbr and select 2310,
Product info at this site contains manual:
Choose Support Resources tab and then select whether or not you have RevB (it will guide you how you can tell).
You can then download the Product Manual. In the non-RevB manual, what to do with SSID is described on p25, showing where in the set-up interface to enter it. The RevB manual will likely be similar, depending on your exact model.
If you don't know how to access the device's settings, send back a comment and I will assist you further.
Sep 13, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link or
if you have belkin router
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
DOES MY D-Link wireless WBR-2310 WORK WITH Windows VISTA?
It should.
They list their Minimum Requirements on the following link:
And as long as your OS is functioning, and you have wireless ability; your OS shouldn't impact the ability to see the router.
Jun 15, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Hi, I need to reset my network key on my dlink wireless model number WBR- 2310
You should find a small button on the device labeled reset. Hold this button in for 5-10 seconds until all the lights blink.
Apr 14, 2009 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
945 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
