Runco Cl 610 keeps shutting down
I have 1300 hours on my bulb and it keeps shutting down, projector lamp and temp go solid red, fan appears to be working
  • meggy2010 Jan 12, 2009
    Our original bulb on our CL610 only lasted 800 hours. We replaced the bulb, then a few months later (4 months out of the 2 year warranty) the projector completely quit. It has been at Runco for the past 2 months and they want to charge us $1,250 to fix it. We have heard this is a common defect but Runco refuses to cover it. "Runco - the world's WORST home theater products." We paid $7,000 for this piece of ****, and it lasted 2 years and 4 months.
  • gdavidj Mar 23, 2009
    I also have a shut down problem. It was a fan problem. Runco replaced under warranty 8 months ago, but the problem has now returned.
  • 22 Answers
On the cl-610 it would shut down after about 5 minutes of well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Posted on Apr 25, 2010
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
Dec 05, 2016 | Office Equipment & Supplies
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Panasonic projector keeps shutting off
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
365 people viewed this question
