Question about Motorola Mobility H700 Wireless Headset
My motorola h700c bluetooth device wont turn on !
When y
  • DavisGladney May 11, 2010
    also all you usually have to do to turn on the Device is open the mic boom (the silver thing over top the ear clip
    can you clarify this question more for me??
Good day, I have a Motorola bluetooth - H700C.
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Apr 20, 2011 | Motorola Mobility H700 Wireless Headset
Need pair number for h700c bluetooth
You can get the pairing for you device on the link below.
http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Good Luck and please rate 4 thumbs up for the free answer
Oct 01, 2010 | Motorola Mobility Bluetooth...
Lost manual h700c...how can i get a password to sync?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Jun 10, 2009 | Motorola Mobility H700 Wireless Headset
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
PASSCODE
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is talk2nazim@yahoo.co.uk
Aug 21, 2008 | Motorola Mobility Bluetooth...
Motorola H700C - purple light
its on paring mode that means that its ready to be pared up with the phone.i would just close it to turn it off and reopen it and connect
Jul 17, 2008 | Motorola Mobility H700 Wireless Headset
How do I connect my H700C?
usually it's pretty simple, you have to turn the h700c on, usually it's by holding the button for few second untill you get the blue light on permanent for a few seconds, now go to your phone and look for the blutooth settings, now you should have an option find other devices. after your phone found the headset you'll have an option "connect" or "pair" or somthing from that kind.
And that's it
Hope this helps
don't forget to rate
All the best
Tom
Apr 10, 2008 | Motorola Mobility Bluetooth...
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Passkey for H700c
The passcode for bluetooth headsets is 0000. Its a default setting.
Jan 04, 2008 | Motorola Mobility Bluetooth...
Motorola Mobility H700 Wireless Headset Logo
150 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
