Question about Lexmark X83 All-In-One InkJet Printer
Lexmark X83 I need to be able to install the ink cartridge on my machine, but have forgotten how to do it. Please help with how to "Install Cartridge" on a Lexmark X83. Thanks
All u have to do is pull the carts forward at the little plastic tabs at the TOP. they will tilt forward (takes a bit of a pull to do it) and then u lift them up and out. color goes on the left (20)~ black goes on the right (70). just slide them down in like u pulled them out, and then push forward a little forcefully, and they will *click* and lock in to place. enjoy
Posted on Sep 22, 2007
    Scholar:
  • 161 Answers
Open the printer door notice the color and the black and white cartridges and remember which one goes where. Write down the print cartridge numbers so you can replace them with the right ones or equivalent ones. Notice the instructions on the printer showing how to remove and to install the cartridges. now proceed with caution. Once youget the new cartridges be sure and remove the strip of tape on the cartridge bottom placed on the cartridges during packing and shipping. Your printer willnot work if you leave these strips on.
Posted on Aug 07, 2007
Open the door on the printer. YOu'll see both cartridges. Pull them towards you until they click, then pull them out. Replace with new:)
Posted on Feb 15, 2007
SOURCE:
I need a installing discs for Lexmark x83
Please visit the Lexmark website to download and install the Lexmark X83 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Should you really need the installation disc, please contact Lexmark Technical Support Center for assistance.
Jan 18, 2012 | Lexmark X83 All-In-One InkJet Printer
Were can I find install help for my X83 lexmark lost my CD
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
May 23, 2009 | Lexmark X83 All-In-One InkJet Printer
Changing the ink cartridge.
I am going to assume that it is a X83.
Here is the link to the user manual. A detailed explanation with pictures starts on page 17...
http://www.lexmark.com/publications/pdfs/x83/engui.pdf
Jan 21, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X83 Problem
be sure to delete your printer and reinstall the printer cd back again but be sure there is only one printer install on your control panel .
Jan 05, 2009 | Office Equipment & Supplies
Lexmark X83 prints streakily or not at all
Have you used a new cartridge.
Do the test for running and cleaning new cartridge heads and the alignment procedure..
(Go to Start, settings, printers, right click on printer then click properties, cartridge maintenance.)
Other thing that might cause problem is build up of ink in right side of machine below printer cartridges.
You will have to strip down machine to get at this area.
Make a note of exactly what action you take when doing this so that you can bits back together.
I use cotton buds to get at the build up of ink or tissue wound round end of pointed object.
Go gently. When you have cleared what you can care reassemble bits and go through above procedure again. Check for any unusual noises that may denote part of mechanism has worn.
Alleluia
PTL
Nov 24, 2008 | Lexmark X83 All-In-One InkJet Printer
WE DO NOT HAVE INSTRUCTIONS ON HOW TO REPLACE INK CARTRIDGES IN OUR PRINTER/SCANNER. iT IS AN x83 Numbers on back ar L1AO109240249
Here is the user's guide,see page 17 for instructions:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 16, 2008 | Lexmark Office Equipment & Supplies
Lexmark X83 Printer Copier Scanner
when u refill the ink in cardge so its cant detact thats y the earror is coming due to its compny ink its happen in all prineters
Feb 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Color cartridge
Turn off and unplug your printer from the wall for a few minutes. Plug it back in and turn it on? If that doesn't work, remove the color ink and make sure the contacts on the cartridge are not smudged, reinsert the ink. If that didn't work re-install the old color cartridge and reboot the computer then try to change to the new color. Let me know what happens, Good Luck, Tim
Feb 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
