Question about Samsung RS2534 Side by Side Refrigerator
Samsung refrigerator RS2534WW ICE MAKER DOES NOT FUNCTION PROPERL
Our ice maker for this model does not function properly. First all, it fills with too much water and then has a problem releasing the cubes - since the cubes don't release when it's time to make more the water flows over the top of the cubes that already exist and we end up with a big mess. can you help?
  • 700 Answers
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Jan 01, 2009
    PLEASE RATE THIS ANSWER WOULD YOU PLEASE. I OPRE THAT IT SOLVED YOUR PROBLEM.
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Water dispenses from frig but ice maker is not producing any ice. We've adjusted the temp up and down and it isn't doing any good. Any suggestions on what else to check?
Before you adjusted the temps, were you having cooling issues? If you were, those cooling issues would need to be resolved in order for your ice maker to function properly.
If you had no cooling issues, the first thing i always ask is when did you last change your water filter, assuming you have one. If you dont have one or it was changed recently, then do the following. Turn the ice maker off for at least one hour, then watch to see if it begins to cycle, the angled row of teeth will rotate. Some models will not operate if the door is open, so close the door light switch while you observe the ice maker. If the ice maker cycles, but gets no water, the ice maker solenoid valve will need to be replaced. If the valve needs to be replaced, you may sometimes find the fill tube that directs water into the ice maker is frozen with ice, this will have to be cleared manually for proper function. If the ice maker does not cycle when you turn it on, you have a bad ice maker or there is a wiring problem with your ice maker system.
Oct 01, 2010 | GE Profile Arctica 25.4 Cubic Feet...
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Dec 03, 2009 | Samsung Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
No water to the ice maker
sounds like the line that feeds the icew maker is possibly frozen up. take a hair drier and remove the icemaker and thaw out the fill tude thats on the top of the freezer.
Jan 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
1,035 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
