Question about Car Audio & Video
Wiring uv7i ltaubin@telus.net Icould still use the color sequence that the factory 16 point power plug is wired. The plug I bought is top left to right is yellow, green/black, green,purple/black, purple, blue/white,blue, bottom row is black,black/white,white,grey/black, grey,orange,pink,red
3 Suggested Answers
  • 139 Answers
SOURCE: What does the stereo colors stand for on an 1992
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Posted on Nov 11, 2010
i need the wiring-order for autorever-head in cassette-deck sunsui D-790WR
the five wires was torn...
Posted on Apr 21, 2012
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
Dec 07, 2012 | Samsung Soc-a101 Hi-res Outdoor Bullet...
I do not have the wiring diagram for a pioneer deh p7800mp.
If you're installing this the easy way to go is go to like walmart and buy a stereo2.gif wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
Sep 21, 2009 | Pioneer DEH-P7800MP
Need wire color codes for pioneer model DEH-P3001B
If you're installing this the easy way to go is go to like walmart and buy a stereo wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Gray...Right front+
White...Left front+
Green...left rear+
Aug 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Searching for wiring harness sequence.
Found a service manual here, but you have to pay for it (only 4.95 USD). It has the wiring block specs you are looking for.
http://www.smpcshop.com/FH-P5000MP-p-3345.html
Best of Luck.
Nov 04, 2007 | Pioneer FH-P5000MP CD / Cassette Player
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
