Question about Kitchen Appliances - Others
Settings for a chefmate refrigerator.
I have a small upright chefmate refrigerator and need to know what is the coldest and warmest setting. 1-9. Thank you very much. May I purchase an owers manual?
  • donniej Dec 05, 2008
    I have a 1.7 cu. ft. chefmate fridge.  It does not respond to the thermostat.  It does not cool at all.  The fan runs fine, just not much cool air circulating.  The light works.  Everything seems to be in order.  No damage.    I took the thermo/ reostat switch off.  All connections seem to be good. Help!
  • k_heil Apr 18, 2009
    My fridge works fine, but I also need to know what is coolest & warmest - the settings are labeled 1-9 and that's it. I've been searching online to try to find a manual.
    Problem Solver:
  • 9 Answers
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Posted on Dec 08, 2008
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Coldest setting 1
o warmest 9 coldest. usually set on 5
Aug 13, 2013 | True GDM-26 Refrigerator
On the inside refrigerator temperature knob is 1 the coolest or warmest temperature?
most often the lowest number is the warmest setting, and the highest number is the coldest setting.
Dec 10, 2010 | Danby Designer DAR1102W Refrigerator
I have an older whirlpool freezer i just need to know on the tempture gage which number is the coldest 1 or higher
usually the higher the number the colder it gets. Easiest way to tell on all models is the number closest to off is the warmest setting... Eric
Sep 13, 2009 | Whirlpool Upright Freezer EV161NZRQ
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Kitchen Appliances - Others Logo
1,405 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
