Question about Panasonic SC-HT730 System
Audio problems with DVD on surround system
The system is hooked and the audio cables are plugged in correctly. The TV sound is fine but when you play DVD's you only hear background music and voices. The main character voices are very faint and hard to hear. The volume goes from -82kb to 0 kb. We can't seem to make it go past 0 to get it into the positive zone. I didn't know if this was normal or not. There is nothing in the manual about this, we've called Panasonic for tech support and continue to get disconnected. I have checked all the audio settings on the system. The speaker for the TV is turned off so you can hear the Tv through the sound system. I'm completely stuck. Please help. Tina
  • mrkstewart3 Jan 20, 2009
    I'm having the same problem...my HT730 system only plays the background music and sounds for some DVDs. It plays the sound from the cable/tv perfectly find...it's just having issues with certain DVDs. Can anyone offer assistance?
  • o110568c Mar 08, 2009
    ditto on the first two comments
  • 4 Answers
- 82k  ^  0k  is normal   it is called consumer output. when you go into the + zone   that is studio grade pro audio.  so this is not your problem... i think  either you have a bad output or bad speakers...... try some other speakers,but careful !  not to blow them with loud volume  if they are not set up for this unit.  hope i could help   also try other on board sound settings when trying other speakers       imanfix
Posted on Oct 24, 2007
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
Getting tv in surround
you need to plug rca cables into the audio out of your tv providing it has them then go to the setting menu in the tv go into the sound options and turn on surround sound
Jul 01, 2010 | Curtis DVD5091 Theater System
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
Oct 07, 2007 | Samsung HT-Q100 System
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Panasonic SC-HT730 System Logo
452 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
