Question about Hitachi 43F300 43" Rear Projection Television
Hitachi 43f300 convergence problem
I have a hitachi 43f300 built august 2003 picture all the sudden went 3d looking. I am told it could be the convergence ic's and possibly some resistors since it is a common problem. When i try the manual adjustment it only adjusts vertically no horizontal. The horizontal red lines do not go straight they bend to the left. my ic's # stk392-110 &stk392-150 do i need to use both these #s or can i use just 110's or 2 150"s and which resistors do you think it is. And on the convergence board is a thing with 3 wires going to the top does the voltage need to be discharged and the best way to do that. Thanks. Whartford@aol.com
  • scc80 Nov 30, 2008
    is thair a way to fix
    Problem Solver:
  • 13 Answers
Just replace the stk-392-110 IC
Posted on Nov 27, 2008
I have the same problem to what do i do
Posted on Nov 30, 2008
Looks like its in 3d red and green
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 14, 2011 | Hitachi 43F300 43" Rear Projection...
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Will not focus
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
Ghosting or distortion on edges of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Hitachi 43F300 43" Rear Projection...
Convergence problem
it sounds as though you need to have the tv converged
Oct 30, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 43F300 43" Rear Projection...
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43 in. Rear hrojection TV
you possibly have a deflection or convergence fault.
Jul 27, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300
possible screen adjustment also,red it set to high,
Sep 18, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
525 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
