Question about Fisher and Paykel GC913 - Stainless Steel Gas Cooktop
Top left burner doesn't turn on
My Fisher and Paykel gas cooktop burner makes sounds (of flint clicking) but the top left burner does not turn on. I can light it with a match but it's irritating. Anyone have a solution to the problem?
  • Anonymous May 03, 2009
    If the electric is plugged in, just have clicking sound ALL the time and still must use match to light burners. I just keep the electric source unplugged.
  • 26 Answers
Need new spark ignighter
Posted on Nov 27, 2008
Left burner not lighting
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
Apr 03, 2014 | DCS 36" Professional Gas Cooktop W/Griddle
Back right burnor ignitor will not turn off, even when knob it turned to off of GC36 gas cooktop
Hi staneand,
I believe your ignition switch has come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 27, 2011 | Fisher and Paykel GC36 Gas Cooktop
How do I remove knobs for burners to clean them?
To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
Gas cooktop igniting and lighting but when you stop the igniting the gas does not stay lit
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Feb 14, 2010 | Fisher and Paykel GC36 Gas Cooktop
Need new middle burner parts
Here is all the I can find for you. Im sure that if you call this company they would have the rest of the parts needed. http://www.fisherpaykelparts.net/cgi-bin/commerce.cgi
Jan 02, 2010 | Fisher and Paykel 36 in. GC901SS Gas...
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
GC913 wok ignitor installation
The electrode goes through the wok burner bowl then the spring fits under the bowl. You have to push it up until it clips into the groove on the electrode. Should be quite a tight fit.
Mar 27, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Fisher and Paykel GC913 - Stainless Steel Gas Cooktop Logo
320 people viewed this question
Top Fisher Cooktops Experts
Paul Carew
Are you a Fisher Cooktop Expert? Answer questions, earn points and help others
