Question about Zenith IQC60H94W 60" Rear Projection Television
How do you clean the mirror?
I have a 15 year old Zenith big screen. How do you get inside of it to clean the mirror?
  • rwilliams155 Mar 22, 2009
    the scren is very dirty. When the picture is dark you can't see anything and we have no idea how to clean it.
    President:
  • 2,992 Answers
It's been a while since I faced one of these, but I believe the bezel around the screen pulls off to expose the screen mounting screws. As I recall it is held on by snap fasteners. It's also possible there is a snap-on trim strip between the screen bottom edge and the speaker grille. If that's the case, remove that to expose screws securing the bottom of the screen. Once they're out the screen swings up and off. Zenith used a couple of methods on different models.
Posted on Nov 27, 2008
I have a mitsubishi dlp tv model wd60735 the picture is not bright any longer any suggestions
I think you have one of the models that have two mirrors inside: not Mitsubishi's best idea.
Most have just the large mirror in the back but I think this model has a very small mirror at the bottom (odd shape about 4x6 inches) behind the front screen which faces upwards and gets dirty from the fans inside the set.
It is amazing how much it can dim the picture; Caution, if yours has it the only way to get at it is to remove the entire front screen assembly---a phone call to Mitsubishi will confirm if your model has the two mirrors----the big one never needs cleaning(almost never and is special).
If you find your model has two mirrors either consider having a pro come out and do it (15 min job) or You Tube it to see if instructions there.
look before you leap as this is usually a two person job.
If you have questions let me know.
I have seen this before in these sets
SD TECH
May 14, 2011 | Mitsubishi Televison & Video
PICTURE HAS BECOME VERY DARK AND DIM ON THE SCREEN
SD TECH
May 11, 2011 | Mitsubishi WD-62725 62" Rear Projection...
My big screen Rear Projection Television set is blurry.
Consider new purchase, your crts are getting old and can't reproduce same quality. High voltage is going and loosing focus. good luck
May 17, 2009 | Zenith R57W46 57" Rear Projection...
How do i clean the mirrors on a big screen tv
In most cases you can remove the back of the TV and get up inside the cabinet to clean the mirror. Windex works great on any glass mirror, but if it is mylar, a less harsh cleaner is better. If you have a newer digital type projection, you will likely have to go in through the screen to get to the mirror and it is much more difficult. I can instruct more depending on type and model of tv.
Dec 06, 2008 | JVC Televison & Video
I have dull areas in my screen (rear projection Mitsubishi WD-62725) the screen is clean, should I clean the mirror an how.
Good Day, tomdebseth;
If these dull areas are soft ball in size and look kind of like fuzz balls, then more then likely the optical engine (light engine) is defective. This part is a bit pricey, $600.00 to $1,200.00. Since your TV is only 4 years old you should go to the manufacture and to get them to pay for this repair. A DLP TV "light engine" should last longer then that.
Good Luck, big IRISH. ps cleaning won't help.
Aug 01, 2008 | Televison & Video
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Feb 19, 2008 | Televison & Video
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
Nov 19, 2007 | Zenith D52WLCD 52" Rear Projection...
Zenith IQC60H94W 60" Rear Projection Television Logo
161 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
