Question about Sanyo Microwave Ovens
How to replace bulb in sanyo lifestyle microwave, 3 years old
  • 456 Answers
Firstly UNPLUG UNIT FROM WALL, secondly, remove the back cover, or the outer shell, what ever you wish to call it, DISCHARGE THE HIGH VOLTAGE CAPACITOR, READ UP ON HOW TO DO THIS IF YOU DONT KNOW!!!!! then its simply of locating the bulb, maybe under another cover, they are sometimes well hidden, and replacing it with another of matching style. Good Luck.
Posted on Nov 27, 2008
I have an old Sanyo Microwave Model EM-FL90N which has worked great, everything works but it seems not to be heating stuff up. The manual is not of much help either. Any suggestions? Help?
Javaid,
You might want to consider replacing the microwave if it is more than 8-10 years old. Sounds like you have a magnatron that is going bad and that is what does the cooking, and to replace it could cost you almost as much as a newer microwave. Hope this helps!
Mar 24, 2016 | Sanyo Microwave Ovens
How do I replace the bulb on a Sanyo EMD9550 combination microwave?
Attached link is to a youtube video for a whirlpool microwave. It may give you enough information to replace the lamp on your microwave. Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Aug 16, 2014 | Microwave Ovens
G.E Microwave model JVM1860 Burning Smell
you must open inside see the diagram, and see 1) burn cable 2) fuse 3) diode 4) capacitor 5) magnetron 6) bulb etc.
God bless you
Nov 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo microwave bulb replacement
replace the bulb if you are shure is faulty. Use the VOM for test the bulb and if there are faulty replace.
go to www.repairclinic.com
God bless you
Jul 19, 2012 | Whirlpool Microwave Ovens
THE BULB HAS STOPPED WORKING ON MY HINARI LIFESTYLE MX905CEGSS MICROWAVE. HOW DO I REPLACE THE BULB?
The bulb of most microwave ovens can only be accessed by removing the main cover.
This is usually a fairly simple procedure and requires only the loosening of a few screws which are situated on the side and/or back of the oven.
Once the cover is removed the bulb should be easily visible & usually consists of the ES or screw in type of connection.
Best wishes,
Graemevm
Mar 24, 2011 | Microwave Ovens
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Nov 16, 2009 | Sanyo Microwave Ovens
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
154 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
