Question about Sewing Machines
Reset Singer 7430 sewing machine
I broke a needle sewing with my Singer 7430. After replacing the needle, the digital panel is blank, and emits a loud beep if I turn it on and off.
I think the computer needs a reset. Is there a button on the machine somewhere?
2 Suggested Answers
  • 980 Answers
SOURCE: My singer sewing machine 7430 keeps acting like
Your machine sounds like it needs retiming unless you are using a needle bigger than a size 16, I can attach instructions if you want to do it yourself.
kendourof@yahoo.com
Posted on Aug 08, 2011
Where are the sensors located in singer 7430?
These machine s are mechanical wonders, always have your machine serviced by trained technician. End user servicing is not recommended, and if needed, parts will not be available to end users so take your machine in for service, repair and adjustments to sew perfectly.
Cheers,
Embroidery Services
San Diego, CA
Jul 25, 2016 | Singer 7430 Sewing Machine
Please explain to me how to adjust the numerical, digital buttons on my 7430 Singer sewing machine?
I just took a look at your user's manual, and boy--you're right, and I've been a computer systems engineer for about 30 years!
Actually, it's easier to figure out by DOING rather than looking at the description on page 35. Basically, selection is divided into two categories--utility, that is, stitches you would use for ordinary sewing, like stretch stitches, zigzag stitches, straight stitch, buttonholes, etc. That is located on the left column, with the arrow keys used for navigation in the middle. The display only shows 5 patterns at a time, so to see all of them, you have to keep pressing the down arrow. Once you have selected the stitch itself, you can then select the stitches width and length, and if it's available for that particular stitch, you can mirror (flip) the stitch, and use a twin needle (if it's available for that design)
The decorative and letter stitches are selected on the right column, and work he same way--they are displayed 5 at a time, etc, and selecting stitch width and length, mirror, and twin needle. However, additionally, you can choose to have the pattern sewn once (the default) or continuously.
I hope that helps!
Sep 21, 2014 | Singer 7430 Sewing Machine
How do I use my Singer 7430 Sewing machine?
Sharon, you must have posted twice--I just answered your question.
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
My singer sewing machine 7430 keeps acting like its catching on something when you turn the handwheel. Also, while sewing all of a sudden the needle hit the plate and broke x2
kendourof@yahoo.com
Aug 07, 2011 | Singer 7430.CL Computerized Sewing Machine
I have a Singer #7430 hardly used, but I thought the needle should be changed as it sounded dull, now i cannot get the needle to stay in when i start sewing the needle falls out and i have broken 3...
some needle clamp screws have a indention where a screwdriver can be put in to turn the screw,,
check to see if your has the indention & if not you need a new needle clamp screw
Nov 04, 2010 | Singer 7430 Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Our Singer sewing machine model 7430 will not stay in time. How do you time it and have it stay in time? It doesn't appear to be a timing belt problem. The machine is new, only a year old with limited...
No timing belt on machine ok, If machine keeps throwing time, the use of the machine is something I would question first or whoever done timing from the start. Finding where the machine is out of time could be the needle bar or hook shaft under unit...when you needle is going up where does the needle pass the cusp of the needle,,, The cusp is the part of the needle that swurves in
Dec 03, 2009 | Singer 7430.CL Computerized Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
